DodgyRog Posted August 12, 2010 Share Posted August 12, 2010 I have had a couple of bolts snap, the one that holds the headlight in at the top and the one that secures the air intake funnel under the headlight. I have drilled the headlight one and I was intending to run it to a local garage to see if they could re thread it for me, but I have run out of time as usual. This is the favour part, don't suppose this is something someone could do for me at the Pod, as my headlights not exactly secure:blink: Keron is bringing me down a spare bolt, so just require the threading bit. I know it's a bit of an odd one, but if you don't ask;) Link to comment Share on other sites More sharing options...
scotty71 Posted August 12, 2010 Share Posted August 12, 2010 So basically you need it chasing ya? Link to comment Share on other sites More sharing options...
JustGav Posted August 12, 2010 Share Posted August 12, 2010 Will have a look when we are up there... will have a tools Failing that, I have plenty of gaffer tape Link to comment Share on other sites More sharing options...
Dnk Posted August 12, 2010 Share Posted August 12, 2010 A simple fix if you've not drilled too big a hole in the old bolt, you just need a metric tap and a tap wrench job done, i can bring these if required. What size are the bolts M6 M8 or M10 ? Link to comment Share on other sites More sharing options...
black_widow87 Posted August 12, 2010 Share Posted August 12, 2010 How big is the whole you want to tapp?? Link to comment Share on other sites More sharing options...
DodgyRog Posted August 12, 2010 Author Share Posted August 12, 2010 Sorry was watching the video on the mad or supposedly not mad swedish twins:blink: So basically you need it chasing ya? If that's what it's called, yeah:blink: Will have a look when we are up there... will have a tools Failing that, I have plenty of gaffer tape Thanks Gav, I could manage the tape part though;) A simple fix if you've not drilled too big a hole in the old bolt, you just need a metric tap and a tap wrench job done, i can bring these if required. What size are the bolts M6 M8 or M10 ? I havn't drilled the hole very big, hopefully How big is the whole you want to tapp?? not sure on the size, it's about that ........big, 10mm head if that means anything Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 12, 2010 Share Posted August 12, 2010 Sounds like it wants Helicoiling to me. M6 is the thread diameter. Link to comment Share on other sites More sharing options...
Dnk Posted August 12, 2010 Share Posted August 12, 2010 (edited) I havn't drilled the hole very big, hopefully not sure on the size, it's about that ........big, 10mm head if that means anything The hole needs drilling carefully in the centre of the bolt and to be just big enough to remove the main part of the bolt but leave the threads behind, the tapping drill size is 5mm for an M6 thread. Sometimes you can pick out the bolt thread and it'll come out in a coil, then just run the M6 tap through just to make sure its clear of any of the thread from the bolt. What size did you drill the hole and is it in the center on the bolt ? Edited August 12, 2010 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 12, 2010 Share Posted August 12, 2010 If a 6mm drill will go through the hole it will need Helicoiling. Link to comment Share on other sites More sharing options...
evinX Posted August 12, 2010 Share Posted August 12, 2010 i drilled a 5mm iirc, got myself a tapper kit from halfords and some oil in a cap and, use a turn and turn back motion, on some of the bolts i was lucky, they just drilled out with the drill:D Link to comment Share on other sites More sharing options...
