Advice on AEM 3 way solenoid
pezzler
Just a quick question - and excuse the kiddy style image! :D
I Have fitted my boost controller; the solenoid is a three way jobby and I have plumbed it in like so..
vac line from compressor housing to port 1 on solenoid, port 3 vented through sintered filter into atmos, vac line from port 2 to wastegate actuator (as pictured below). Wastegate VSV capped off, wastegate actuator capped off.
When energized, ports 1 and 2 are open - compressed air flows into wastegate actuator, opening the wastegate.
When passive (is that the right term??), compressed air flows through port 1 and out of port 3 through the filter into the engine bay.
Just wanted to check that this is all plumbed in the correct way before firing it up
Cheers
