Strange gearbox problem..??
Lurch
Hello, my gearbox has started playing up. I did a few drag runs and my first one was fine. Done another one 20mins later and it would not go in 2nd, so I put it in 3rd, then it wouldn't go into 4th easily, but did eventually. After a bit of messing about putting it into all the gears whilst standing still I tried another run and it was ok.
But now every now and then whilst driving normally when I put it into 2nd the part of the gear knob that you pull up to put into reverse seems to go up itself when I put it in 2nd and 4th and it doesn't feel right, other times it can be normal.
I'm thinking its a combination of the oil/ heat making the oil thinner and something up with the selector part of the gearbox.
Anyone have any ideas what I can do from now? I'm quite happy to take the box out and have a fiddle...
I'm not 100% sure as I've never been in or driven another manual supra before, but I may have a short shifter as the gearstick seems low and doesn't travel much when changing gear, maybe that wouldn't help?
Is that something that can be changed with the gear box still attached to the car or gearbox out? The bushes I mean?
Edited by Lurch (see edit history)
It is difficult but not impossible to do with the box in place. If you can get the car on a ramp, access is easier if you pull the box down after undoing the box rear mount bracket and removing the front section of the prop,( match marks essential). It may be the short shift mech, (total waste of time IMHO) the stock stick in not exactly very long. The V160 is heavy shift at the best of times, why anyone would want to lower the leverage available, just does not make sense.
Thanks for the advise, I will try what Steve and Chris suggested in the hope its an easy fix otherwise it will be what you just suggested!
Check the 4 bolts that hold the gear stick in place under the rubber cover, I had one of these break a while back and the bolt was sitting on top stopping the car from selecting certain gears.
Thanks I will be trying that tomorrow. Would be very nice if thats all it is.
I agree, or they could have come loose. It's a 5 minute job from within the car.
Hopefully. Thought it was a new gearbox when it wouldn't go into gear!
Both of you were spot on!!
Thank god for that! I was seriously thinking new gearbox, which would have been impossible for me at the moment!
Thanks everyone for your help. Thanks for the offer Dude!
This means I can actually take the supra to suprapod now!
