supra steveo Posted August 10, 2010 Share Posted August 10, 2010 what the hell ive only had the thing a week and on my way to pick up the UK brake calipers tonight it just went pop after about 10 secs of fairly loud music, at least the JL 12W0 lasted 3 yrs but this vibe one, even tho i thought it was louder only lasted 1 week , do i take it back to halfords and ask for another one ?? halfords, yeah i know, but i had a 10 hr journey i wasnt going to listen to the front mids on there own Link to comment Share on other sites More sharing options...
Lee P Posted August 10, 2010 Share Posted August 10, 2010 what the hell ive only had the thing a week and on my way to pick up the UK brake calipers tonight it just went pop after about 10 secs of fairly loud music, at least the JL 12W0 lasted 3 yrs but this vibe one, even tho i thought it was louder only lasted 1 week , do i take it back to halfords and ask for another one ?? halfords, yeah i know, but i had a 10 hr journey i wasnt going to listen to the front mids on there own Sounds like you have another issue there, or there is something wrong with your ears. Take it back and get it swapped, they should do it. Link to comment Share on other sites More sharing options...
mawby Posted August 10, 2010 Share Posted August 10, 2010 Is it the same amp? Maybe that's the problem if you've blown two subs in as many weeks. Link to comment Share on other sites More sharing options...
monsween Posted August 10, 2010 Share Posted August 10, 2010 Could be the amp as mawby said, but your first flaw was halfords. Ive had my alpine type r 12" sub for 3 flawless years. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 10, 2010 Share Posted August 10, 2010 Have you thought about having your hearing aid serviced:p Link to comment Share on other sites More sharing options...
supra steveo Posted August 10, 2010 Author Share Posted August 10, 2010 lol maybe it this dutch hardstyle stuff ive started listening to Link to comment Share on other sites More sharing options...
RobD Posted August 10, 2010 Share Posted August 10, 2010 I've got a vibe slick 12" sub for sale if you need it bud, although I'd say you've got problems elsewhere as mine has been up quite loud in it's time and hasn't gone! Link to comment Share on other sites More sharing options...
hodge Posted August 10, 2010 Share Posted August 10, 2010 Was it brand new Steve. If so you havecto run a sub in for I think off the top of my head 20hrs before you can wack it up. Slowly increase the volume over the 20 hrs so the diaphram has time to stretch. Turn it straight up from new and there's a good chance it's gona pop. Link to comment Share on other sites More sharing options...
Suprab1 Posted August 10, 2010 Share Posted August 10, 2010 No matter how bad the sub none should blow after a week. Vibe though would be a good brand of sub & should last untill you want to change it. I would check your amp as already said. What power is your amp? Also what power is your sub? If your amp is under powered it can & will damage your subs. Link to comment Share on other sites More sharing options...
hodge Posted August 10, 2010 Share Posted August 10, 2010 My moneys on it's been turned on too loud before running in time was complete I've seen it loads of times. Link to comment Share on other sites More sharing options...
hodge Posted August 10, 2010 Share Posted August 10, 2010 If it does turn out to be the amp I've got a Jackson 5 channel cometition amp for sale. Link to comment Share on other sites More sharing options...
jackso11 Posted August 10, 2010 Share Posted August 10, 2010 if you need the music so loud it is blowing the subs, you need your ears syringed. You must have massive wax blockage Link to comment Share on other sites More sharing options...
Abz Posted August 10, 2010 Share Posted August 10, 2010 if you need the music so loud it is blowing the subs, you need your ears syringed. You must have massive wax blockage Amp's can blow subs quite easily, were they spec against each other or did you just use the amp as it was the old one? Link to comment Share on other sites More sharing options...
johnny g Posted August 10, 2010 Share Posted August 10, 2010 Are you cross overs/pass filters working ok? Too much volume with higher frequencies isn't good for them either... Link to comment Share on other sites More sharing options...
aman00123 Posted August 10, 2010 Share Posted August 10, 2010 Was it brand new Steve. If so you havecto run a sub in for I think off the top of my head 20hrs before you can wack it up. Slowly increase the volume over the 20 hrs so the diaphram has time to stretch. Turn it straight up from new and there's a good chance it's gona pop. I agree, 20 hours is about the minimum and you should probs start from the amp, i.e. turning the power up from the amp slowly. I think the other issue you had was Vibe, not the best subs, go for a JBL GTO (about £40 iirc), amazing sub as they actually made a better sub than they thought they had! These were louder and had a better sound than my JL 12w3v3 's!! Mind you I had a custom box made by vxincar for material cost (the owner was up and I know him very well) Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 10, 2010 Share Posted August 10, 2010 see what they say but if its the voice coil thats gone they most probly want swap it. I had a brand new sub and amp for sale dirt cheap for a month but its sold now Link to comment Share on other sites More sharing options...
nevins Posted August 10, 2010 Share Posted August 10, 2010 how have you set it up? gain, cross over etc Link to comment Share on other sites More sharing options...
SupraP-Z Posted August 10, 2010 Share Posted August 10, 2010 I agree, 20 hours is about the minimum and you should probs start from the amp, i.e. turning the power up from the amp slowly. I think the other issue you had was Vibe, not the best subs, go for a JBL GTO (about £40 iirc), amazing sub as they actually made a better sub than they thought they had! These were louder and had a better sound than my JL 12w3v3 's!! Mind you I had a custom box made by vxincar for material cost (the owner was up and I know him very well) +1 brilliant subs for the money, as are the gt4's - demonstrated by VXInCar in a few youtube videos. They can really take a hammering! Link to comment Share on other sites More sharing options...
supra steveo Posted August 10, 2010 Author Share Posted August 10, 2010 Well I got a new one today , they just exchanged it, I rekon the voice coil had gone too , on pushing the cone down it was crunching It's a slick 12 vibe sub the spec is better than the JL 12W0 we will see what happens with this sub but I think I need the amp checking out too Link to comment Share on other sites More sharing options...
