wallis Posted August 9, 2010 Share Posted August 9, 2010 I think my wife may leave me after this lot but after a few bad weeks with the car I have decided to go single I’m getting two second hand tubbies fitted next week to get the car moving again as a temp measure, then hopefully when I get all the parts sourced in the next month or so I’m going for it;) I’m quite excited as its being done at Corten Millers and this is going to be there first single supra they have ever done including the mapping so I guess it’s going to be pretty special for everyone involved. I’ve been well impressed with their knowledge and enthusiasm so far and after their front page article in banzai mag the other month I’m buzzing about the thought of these guys doing my single conversion! I think I have got everything covered but please do tell me if I have missed anything out, I also wanted to know if u can use the stock fuel rail for 650cc injectors or should I change it? Here’s my list so far: HKS T04R T4 Turbo (up to 600BHP 35psi) T4 Turbo Flanged SS T-304 manifold with 50mm Wastgate New ECU mapped by Corten Millers Apexi AVC-R Boost controller Apexi EGT Gauge 650cc Injectors High flow Fuel Rail ? Front mount cooler New Fuel Pump New gearbox cooler Oil/aux lines for new turbo BOV & Induction Kit. I’ve got everything apart from the injectors, Fuel rail, fuel pump & auto gear box cooler so any advise on this lot would be great guys plus if I’ve missed anything off the list. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2010 Share Posted August 9, 2010 (edited) What ECU are you going for Matt? Exhaust sytem, size and style, downpipe, V band or bolted, wideband, bigger rad... Edited August 9, 2010 by Swampy442 (see edit history) Link to comment Share on other sites More sharing options...
Scott Posted August 9, 2010 Share Posted August 9, 2010 What power are you looking to run? You might be at the limit of the gearbox even with coolers. You will definitely want an AFR gauge. You're a brave man getting something like a single fitted and setup by people who haven't done it before. Best of luck to you Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 What ECU are you going for Matt? Exhaust sytem, size and style, downpipe, V band or bolted, bigger rad... ECU wise CM's are sorting out, its not going to be cheap but they said they will find away, i dont know what ecu they will go for at the moment its in their hands. Exhaust wise im fine i have a 3.5 inch straight through fitted now, downpipe i guess needs to fit my existing system so i think thats going to be down to CM's also to sort....lol Ive just bought a stainless Steel rad from japan which i hope will do the trick craig cooling wise? Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 9, 2010 Share Posted August 9, 2010 Bad move in my opinion, I would never want to be the guinea pig unless they were sponsoring it ................sorry Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 What power are you looking to run? You might be at the limit of the gearbox even with coolers. You will definitely want an AFR gauge. You're a brave man getting something like a single fitted and setup by people who haven't done it before. Best of luck to you ill be happy with 500bhp im not power crazy! AFR gauge is already fitted with oil temp & boost bud, Im kool with these guys doing the work they know there stuff, just because its a supra and they havnt done one before doesnt mean they dont know what there doing, everyone keeps telling me how simple going single is compared to the twins setup. Link to comment Share on other sites More sharing options...
Scott Posted August 9, 2010 Share Posted August 9, 2010 Bolting the bits on is pretty easy. Setting it up is a bit of an art. Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2010 Share Posted August 9, 2010 (edited) Here’s my list so far: HKS T04R T4 Turbo (up to 600BHP 35psi) T4 Turbo Flanged SS T-304 manifold with 50mm Wastgate New ECU mapped by Corten Millers Apexi AVC-R Boost controller Apexi EGT Gauge 650cc Injectors High flow Fuel Rail ? Front mount cooler New Fuel Pump New gearbox cooler Oil/aux lines for new turbo BOV & Induction Kit. Better to buy a full kit, everything will fit together perfect that way, buying bits here and there can work out to be a right pita to get together, costly if you need lots of fabrication. Why T04r? thats an old turbo now, much better out there. Stock fuel rail and FPR/lines are fine at the power you want, they are good for an easy 700bhp, just get some bigger cc drop in injectors, try and go for high imp, that way you wont need the agro or mess of having a resistor pack. If they are good mechanics you should be ok, its not hard to bolt a kit on, mapping on the other hand i would go with tried and tested, Ryan. Edited August 9, 2010 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted August 9, 2010 Share Posted August 9, 2010 U can use 650cc or 800cc drop ins with the stock rail. As above you're brave to be their first ever single customer so hope i works out well. Gearbox coolers give Lee P a pm he does good ones and only around £100 each. If you have jspec brakes they'll need upgrading mate. Also need a decent oil cooler. Gearbox temp gauge is handy Link to comment Share on other sites More sharing options...
Jamesy Posted August 9, 2010 Share Posted August 9, 2010 (edited) You should try and find out what ecu theyre using as so many options. Edited August 9, 2010 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Homer Posted August 9, 2010 Share Posted August 9, 2010 Spot on Jamie, had exactly the same thoughts after reading the spec list in the first post Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 Better to buy a full kit, everything will fit together perfect that way, buying bits here and there can work out to be a right pita to get together, costly if you need lots of fabrication. Why T04r? thats an old turbo now, much better out there. Stock fuel rail and FPR/lines are fine at the power you want, they are good for an easy 700bhp, just get some bigger cc drop in injectors, try and go for high imp, that way you wont need the agro or mess of having a resistor pack. If they are good mechanics you should be ok, its not hard to bolt a kit on, mapping on the other hand i would go with tried and tested, Ryan. thx for the advise mate spot on, im glad thats cleared up the fuel rail and injector side of things, so 650's will be fine to drop straight in and just change to a bigger fuel pump. Turbo wise its just because the price is right and ive read up there really solid and reliable, the kits are great but u pay through the nose for them, making it up yourself makes it abit more interesting to do, different i guess exciting! Ive got to ask what turbo would u go for mr P out of interest? Also i dont want to change my auto box/clutch so im only looking for 500-550bhp im not wanting to go crazy i do have a budget....lol Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 U can use 650cc or 800cc drop ins with the stock rail. As above you're brave to be their first ever single customer so hope i works out well. Gearbox coolers give Lee P a pm he does good ones and only around £100 each. If you have jspec brakes they'll need upgrading mate. Also need a decent oil cooler. Gearbox temp gauge is handy cheers for the info on the gearbox cooler kit mate ill get one ordered Yeah brakes will be on the next list of things todo before next summer for sure. Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2010 Share Posted August 9, 2010 thx for the advise mate spot on, im glad thats cleared up the fuel rail and injector side of things, so 650's will be fine to drop straight in and just change to a bigger fuel pump. Turbo wise its just because the price is right and ive read up there really solid and reliable, the kits are great but u pay through the nose for them, making it up yourself makes it abit more interesting to do, different i guess exciting! Ive got to ask what turbo would u go for mr P out of interest? Also i dont want to change my auto box/clutch so im only looking for 500-550bhp im not wanting to go crazy i do have a budget....lol For the power you want i would go precision billet 6262 on a .81 ar. Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 For the power you want i would go precision billet 6262 on a .81 ar. Ok mate cheers ill look into that now, jaime is it on a t4 flange? its just i have paid and ordered the manifold already! Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2010 Share Posted August 9, 2010 Yes its T4. Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 Yes its T4. price is ok on these to it appears, sorry to ask jaime but would u buy one from USA direct or is there some where in the uk who stocks them at a good price? sexy looking thing too....me likey! Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 9, 2010 Share Posted August 9, 2010 Drop dan1985 a pm, he's got a precision 6262 for sale, he got it from dude, brand spanking new Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2010 Share Posted August 9, 2010 price is ok on these to it appears, sorry to ask jaime but would u buy one from USA direct or is there some where in the uk who stocks them at a good price? MVP. http://www.mkivsupra.net/vbb/showthread.php?t=222604 Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 Drop dan1985 a pm' date=' he's got a precision 6262 for sale, he got it from dude, brand spanking new[/quote'] i saw he bought it for £900 a while ago from dude, im just looking but u can get it in the US for £550 + p&p unless im reading it wrong....lol Ill tap dan up, i see he's not had allot of offeres on it yet. Link to comment Share on other sites More sharing options...
dude Posted August 9, 2010 Share Posted August 9, 2010 For the power you want i would go precision billet 6262 on a .81 ar. Spot on JP thats what I was just going to reccomend, T04 will be horrible on an auto, also decent management to get some spool into it, madness not know what ecu etc is going on, if you don't like it will the garage refund your money???? Link to comment Share on other sites More sharing options...
dude Posted August 9, 2010 Share Posted August 9, 2010 i saw he bought it for £900 a while ago from dude, im just looking but u can get it in the US for £550 + p&p unless im reading it wrong....lol Ill tap dan up, i see he's not had allot of offeres on it yet. Thats not a DBB, he actually bought it from a customer of mine, just that I had it!!! PM if you want a price on an air cooled DBB 6262, ask Miko Supra what they go like;) Link to comment Share on other sites More sharing options...
wallis Posted August 9, 2010 Author Share Posted August 9, 2010 Spot on JP thats what I was just going to reccomend, T04 will be horrible on an auto, also decent management to get some spool into it, madness not know what ecu etc is going on, if you don't like it will the garage refund your money???? Hey dude, thx for the input mate i understand u think i might be mad about not knowing what management im going to be using yet but i only decided today to go single and will find out hopefully what they can offer me by the end of this week. Maybe im just over excited and might have to have a re-think but im going to give these guys a chance, everyone starts some where there one of the countrys top evo and scooby tuners so they do know there stuff. Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 9, 2010 Share Posted August 9, 2010 I ran a TO4R on an Auto Supra, was at 550bhp, it destroyed the Auto box just FYI, its an old turbo now compared to the new stuff You would be wise to spend your hard earned money with a garage that has done the single conversion many times not one that is about to learn the process, the Auto box needs a very special set up as not all ECU's support this well Please take a step back, ask more questions and do the job once and do it right and you will be a happy man Link to comment Share on other sites More sharing options...
Jamesy Posted August 9, 2010 Share Posted August 9, 2010 Good point. They need to know that if u get a standalone ecu they'll also need to keep the stock ecu fitted too to control the autobox Link to comment Share on other sites More sharing options...
