SupraStar 3000 Posted August 9, 2010 Share Posted August 9, 2010 noticed on the way to work the orange warning light came on when braking hard. Seemed to only happen during the first 15 minutes of the journey to work. I assume the brake fluid is low (will check later) but could it be anything else. thanks. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 9, 2010 Share Posted August 9, 2010 its your break fluid low mate or pads at worst case Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 9, 2010 Share Posted August 9, 2010 Quote Link to comment Share on other sites More sharing options...
Kirk Posted August 9, 2010 Share Posted August 9, 2010 Brake pads I'm saying seeming its only happening under braking Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 9, 2010 Share Posted August 9, 2010 When the brake fluid gets anywhere near being under the MIN mark any sloppage around in the resevoir (i.e when you accelerate, corner hard or brake) causes the warning light to come on. However the low level might be caused by the pads being worn down, so check both. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted August 9, 2010 Author Share Posted August 9, 2010 thanks guys - Nice to have some reassurance. I'm sure its just brake fluid as its seems to disappear after sloshing around awhile - also changed the pads myself not long ago. I'll take a look tonight. Quote Link to comment Share on other sites More sharing options...
Ark Posted August 9, 2010 Share Posted August 9, 2010 I sometimes get this on trackdays - the pads wear down during the day so the fluid level drops in the reservoir. A quick top up fixes it. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted August 9, 2010 Author Share Posted August 9, 2010 cheers mate. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted August 9, 2010 Author Share Posted August 9, 2010 It didn't seem to come on during the drive home but I've toped up with some DOT 5.1 ,.. although the electric plug that reads the level seemed very loose and clicked back into place when pushed, so I suspect that to be the culprit Fingers crossed Quote Link to comment Share on other sites More sharing options...
