VVTI Valve stem seal replacement
Guest phatGZ
Guest phatGZ
Hi
Awesome how to write up on valve stem seal replacement.
Wanting to know if anyone has done this on a VVTI?
if so are there any major differences/challanges than replacement on the non-vvti 2jz-gte?
with the intake side are the seals different or same parts/part numbers as the non-vvti?
i realise the cam cover and gasket is different on the intake side but would there be other part differences?
VVTI's are not that common in aus, your site is by far the most helpful!
Thanks
