4in pipe for Boostlogic cat-back
Homer
I have a BL 4 inch rear box, but no pipe to connect it to the 2nd cat. Any bright ideas where I could get something made up, or even something off the shelf that might fit?
I've mailed BL but have no reply yet, however expect it to be rather expensive...
I use allround engineering in slough for all my fabrication work (they built my 5" system) i have never given them a car before though, i normally just give them stuff to copy.
If you decide to sell it i will be interested as my rear box is bashed up.
If you have the time to get under there yourself and cut it all to length then here a few sources for bits. Could save yourself a whole lot of money and just take it to a competent welder to weld it up after you've trimmed it to size and marked it up.
1) Flange http://cgi.ebay.co.uk/3-Exhaust-flange-Stainless-Steel-Universal-/260511933311?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ca7b8a37f
2) Expand to 4" http://cgi.ebay.co.uk/4-3-stainless-steel-tube-reducer-exhaust-pipe-/220438668241?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item33532b23d1
3) 4" stainless tube http://cgi.ebay.co.uk/4-101-6mm-T304-Stainless-Steel-Exhaust-tube-PIPE-1m-/370337617320?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5639d795a8
4) Hanger rod https://www.jetex.co.uk/jetex/store/index.php?_a=viewProd&productId=3077
5) A rubber mount https://www.jetex.co.uk/jetex/store/index.php?_a=viewProd&productId=3051
If you have to have a smooth bend anywhere then you could trim this to suit:
6) Bend https://www.jetex.co.uk/jetex/store/index.php?_a=viewProd&productId=3017
And depending on the back box connection (welded or slip fit) you may want one of these:
7) Clamp https://www.jetex.co.uk/jetex/store/index.php?_a=viewProd&productId=3026
Edited by dandan (see edit history)
Excellent info Dan, thanks a lot!! that could be a plan. I don't mind doing the cutting and have a very good welder local :)
For info, I just heard back from Zohair at BL, the pipe on it's own is $550 so about £400 delivered. Not as back as I thought, but still quite expensive for a bit of drainpipe :D
Thats not bad, do it come with the 2bolt to 4" V band adaptor an all?
