Supra Dubs
McCaberSupra
any dub supra owners want to organise a meet in the next week or so? i just got one n wud love to check out everyone elses stuff!
I would Advise you get SSI (Marty & Colin) to do a check over ;); if she is just in from Japan
http://www.supraspecialists.moonfruit.com/
If you are any where near Swords I dont mind meeting up, just goin up to SSI on Thurs so anytime after that
oh up north. stressssssssssss. whats their set up like up there? and no its a red supra. spec list isnt massive to be honest. sure come check her out when ur back. im only new to the game so I need all the advice/help i can get...
Best advice I can give is, dont let anybody touch her down in the republic unless its a basic oil change
Get her up to SSI to make sure everything is hooked up and running as it should, plus up in NI they are roughly half the price in labour compared to the goin rate down here so works out the same with Petrol but with the bonus Colin and Marty actually know what they are doing.
My plan is to do an annual run up to SSI for a check over and maintain her myself in-between
Any Questions just ask one of us if you want or if you are uncertain about anything ;)
Ok thanks man I'll defo bring her up there when I can.
What would the regular service intervals be? In terms of oil changes, plugs and so on.
Thanks :D
Get ready
I Service my car every 10,000KM, oil, and Diff oil/ oil filter
Gearbox every 2 years , or 35.000KM
Fuel Filter every 25,000KM
Plugs depending on your Spec, BPU etc you need a colder plug, I use Denso Iridium - IK22, explanation of Plugs in FAQ below
Oil - I use Motul 10W40 or if you like track days 10W50 OR I use Fuchs Silkolene Pro S 10W50 (Now called Titan Race)
Air Filter -- I got the K&N panel filter (Stick with you OEM air Box)
I just clean this as it needs(Life time Warranty)
Oil Filter -- I use K&N Oil Filters
Gerbox Oil -- I use Motul Multi ATF
Other than that I just maintain her, the FAQ will have greater Detail, I would recommend you get the K&N Panel filter; you save money in the long run and you are guarenteed it is filtering the Air; I found the paper air filters hit and miss on quality control
Oil
http://www.mkivsupra.net/vbb/showthread.php?t=56684&highlight=faq+Oil
Spark Plugs
http://www.mkivsupra.net/vbb/showthread.php?t=41927
