Guest chris'urx Posted August 5, 2010 Share Posted August 5, 2010 i have not long had my supra and this one came roud at just the right time i found it sitting in a shed in dry store and it only cost me 1,500 and am looking at doing a engine and gear box swap from na to big ass turbo and auto to man any advice thanks Chris Link to comment Share on other sites More sharing options...
safcdixon Posted August 5, 2010 Share Posted August 5, 2010 sell the engine and box for a profit,sell ur n/a and buy a tt Link to comment Share on other sites More sharing options...
Guest chris'urx Posted August 5, 2010 Share Posted August 5, 2010 would i not just be cheeper to swap the engine and box and change the brakes Link to comment Share on other sites More sharing options...
safcdixon Posted August 5, 2010 Share Posted August 5, 2010 its all the hassle though mate, and engine swaps never seem to go smoothly theres alot to change, im sure someone with more knowledge in supras than me will help soon i think you could get a good tt for the money you'd have after selling the two, what gearbox is it? Link to comment Share on other sites More sharing options...
Guest chris'urx Posted August 5, 2010 Share Posted August 5, 2010 the car has been in the country 4 years and only done 90,000 km 140 of witch are in this country and she is all mint apart from a crack in the bumper no rust no damage and i have some one to help me with the change just wanted to know if anyone eather had parts or any think i should look out for Link to comment Share on other sites More sharing options...
Terminator Posted August 5, 2010 Share Posted August 5, 2010 If you check out the Tec Ref section of the forum there are some really good threads in there that may answer a lot of your question. There is even a how to swap boxes. It really depends on what you want to achieve, if you just want to own a 6 speed daily driver then just buy one. However if you want a car you can treasure and really feel proud of then build one. The process is not with out its headaches and it takes time to do properly. While you are doing it you may want to add a single turbo etc. So you end up with a very different sort of car. Unless you want to get sucked into a money pit, set a budget and stick to it. Link to comment Share on other sites More sharing options...
safcdixon Posted August 5, 2010 Share Posted August 5, 2010 ok if your attached to the car then its a good option to have, just thought i would put the idea there thats all, best of luck with it, try putting the question in tech Link to comment Share on other sites More sharing options...
Guest chris'urx Posted August 5, 2010 Share Posted August 5, 2010 will do thanks guys and i was reading that if you want to run more power to run the 5 speed box and a single turbo Link to comment Share on other sites More sharing options...
safcdixon Posted August 5, 2010 Share Posted August 5, 2010 6speed box is better mate but are expensive Link to comment Share on other sites More sharing options...
Guest chris'urx Posted August 5, 2010 Share Posted August 5, 2010 how much are thay and how rare are thay Link to comment Share on other sites More sharing options...
safcdixon Posted August 5, 2010 Share Posted August 5, 2010 I think you can get them for bout 2000, you can get the r154 box from a mkiii which is 5 speed but these are rare also, check the driftworks website Link to comment Share on other sites More sharing options...
Terminator Posted August 5, 2010 Share Posted August 5, 2010 Six speed boxes come up for about £1800. The 5 speed box is not really strong enough fora decent single. It would end up being the weakest point of the car. Link to comment Share on other sites More sharing options...
HadeS Posted August 5, 2010 Share Posted August 5, 2010 5 speed w58 it's not gonna work with single but r154 can handle it very well. Link to comment Share on other sites More sharing options...
ilicos Posted August 5, 2010 Share Posted August 5, 2010 (edited) . The 5 speed box is not really strong enough fora decent single. It would end up being the weakest point of the car. In the case of the W58 5-speed this is true, but I think the R154 is good for 700hp and about 550-600ft/lbs torque. Someone correct me if the figures are a bit out. Edit = ^ Beaten to it:d Edited August 5, 2010 by ilicos (see edit history) Link to comment Share on other sites More sharing options...
