crank pulley help
Guest kennyboy
Guest kennyboy
hi all can some one tell me if light weight pulley set are any good to put on supra n/a as i have just done the tipex test on its way out :please:
Guest kennyboy
Not advisable, its a damper as well as a pulley. Just stomach it and get a gen Toyota one
Hi thanks for the reply would you say replace the belt to, and would you no how much for a gen crank pulley.
Change items as suggested above.
An I believe a new one from Mr T is just over £200 for the crank pulley.
whifbitz are cheapest by a margin. Toyota where looking over £220 for one and I think that included my discount. Woudln't recommend a used one either, they seem to go quite randomly so you could buy a used one and it could go the same way a month or two down the line. Also, I think toyota modified the crank pulley, i seem to remember reading that somewhere.
