Guest kennyboy Posted August 4, 2010 Share Posted August 4, 2010 hi all can some one tell me if light weight pulley set are any good to put on supra n/a as i have just done the tipex test on its way out Link to comment Share on other sites More sharing options...
Swampy442 Posted August 4, 2010 Share Posted August 4, 2010 Not advisable, its a damper as well as a pulley. Just stomach it and get a gen Toyota one Link to comment Share on other sites More sharing options...
Nic Posted August 4, 2010 Share Posted August 4, 2010 Fit a genuine Toyota crank pulley (Harmonic Balancer), they are properly weighted and balanced. Have a read HERE for full explanation. Link to comment Share on other sites More sharing options...
Guest kennyboy Posted August 4, 2010 Share Posted August 4, 2010 Not advisable, its a damper as well as a pulley. Just stomach it and get a gen Toyota one Hi thanks for the reply would you say replace the belt to, and would you no how much for a gen crank pulley. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 4, 2010 Share Posted August 4, 2010 while you have the crank pully off replace as much as you can afford to. if you pokets allow it its sensible to do the cam belt , crank seal and oil pump while its all off Link to comment Share on other sites More sharing options...
Abz Posted August 4, 2010 Share Posted August 4, 2010 Hi thanks for the reply would you say replace the belt to, and would you no how much for a gen crank pulley. Change items as suggested above. An I believe a new one from Mr T is just over £200 for the crank pulley. Link to comment Share on other sites More sharing options...
caseys Posted August 4, 2010 Share Posted August 4, 2010 Check with whifbitz. I'm sure they beat the Toyota price. Link to comment Share on other sites More sharing options...
Dave Posted August 4, 2010 Share Posted August 4, 2010 or ask keron he might have a good 2nd hand one Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted August 4, 2010 Share Posted August 4, 2010 whifbitz are cheapest by a margin. Toyota where looking over £220 for one and I think that included my discount. Woudln't recommend a used one either, they seem to go quite randomly so you could buy a used one and it could go the same way a month or two down the line. Also, I think toyota modified the crank pulley, i seem to remember reading that somewhere. Link to comment Share on other sites More sharing options...
Guest kennyboy Posted August 6, 2010 Share Posted August 6, 2010 Hi just went down to the deals crankpulley gobsmacking 243.86+42.68=£286.54 i think i`ll go to whifbitz Link to comment Share on other sites More sharing options...
