Guest Johnnynhl Posted August 4, 2010 Share Posted August 4, 2010 My Aircon has not worked for a number of years. recently I took it to get it charged but the garage but unfortunately according to the gargage the condensor and several other bits (as they whistled through their teeth) were required totalling £500 plus in parts and labour. Has anyone modded the car and removed the compressor?. Lets face it I live in Scotland and have no intention of sellin my beast, in fact I may just get buried in it, so why bother spinning the compressor. Anybody got a fix? Quote Link to comment Share on other sites More sharing options...
Wez Posted August 4, 2010 Share Posted August 4, 2010 You can remove it, all you need is a smaller belt. Quote Link to comment Share on other sites More sharing options...
S.H. Posted August 4, 2010 Share Posted August 4, 2010 Can be done in a couple of hours. All you need is a smaller belt if you want to remove i completly. Quick fix: http://www.mkivsupra.net/vbb/showthread.php?t=223606 Steffen Quote Link to comment Share on other sites More sharing options...
Guest Johnnynhl Posted August 6, 2010 Share Posted August 6, 2010 Great thread do you have the part number for the belt? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 6, 2010 Share Posted August 6, 2010 6PK1840 in a good make from your local motor factor will work buddy. If you decide otherwise I have a compressor here you can have at a good price. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2010 Share Posted August 6, 2010 I also have a compressor for sale Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 6, 2010 Share Posted August 6, 2010 I also have a compressor for sale Me too as it happens Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 6, 2010 Share Posted August 6, 2010 6PK1840 in a good make from your local motor factor will work buddy. We used a PK1863 belt and that worked. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 6, 2010 Share Posted August 6, 2010 We used a PK1863 belt and that worked. There are probably several sizes that will do the job nicely. However I'd imagine the bigger the belt the greater the chance there is of it slipping on the pulleys due to a lack of tension. Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 6, 2010 Share Posted August 6, 2010 There are probably several sizes that will do the job nicely. However I'd imagine the bigger the belt the greater the chance there is of it slipping on the pulleys due to a lack of tension. Hmmm, will have a look, but it is was FT when it went on, with graham grunting doing the tensioner Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 6, 2010 Share Posted August 6, 2010 Hmmm, will have a look, but it is was FT when it went on, with graham grunting doing the tensioner Would there be a difference between turbo and non turbo OEM belt sizes? I have the non turbo Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 6, 2010 Share Posted August 6, 2010 Would there be a difference between turbo and non turbo OEM belt sizes? I have the non turbo Hmmm, got me thinking now.... I'll have to double check, this was on an NA as well.... I remember seeing 1865 as being the usual belt length but we couldn't one so had to go for 1863.... Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 6, 2010 Share Posted August 6, 2010 Well I double checked the size and it's a Gates Micro V - 6PK1840 The original belt, or at least the one I replaced when I remove the A/C, was 6PK1940. Is there a possibility that the belt could be fitted in a couple of ways without upsetting anything? Quote Link to comment Share on other sites More sharing options...
