jackso11 Posted August 4, 2010 Share Posted August 4, 2010 Manual conversion time soon... There are loads of threads on this but I can't find one that exactly answers my question. Would a Pre-facelift LSD Auto TT diff be ok with a v161 gearbox when doing a manual conversion? or would I need to replace the diff too. Also, am I right in thinking that not all facelift diffs are LSD? I am timing you experts on this one Link to comment Share on other sites More sharing options...
Nic Posted August 4, 2010 Share Posted August 4, 2010 Yes it'll be fine to use. Not sure if the final drive gearing is different though on the auto, if it is then it will effect the gearing, hopefully someone will be along shortly to confirm. Link to comment Share on other sites More sharing options...
jackso11 Posted August 4, 2010 Author Share Posted August 4, 2010 I think the gearing will give me a bit quicker acceleration with this diff, there are so many different types though I am not too sure! Link to comment Share on other sites More sharing options...
jimmenico Posted August 4, 2010 Share Posted August 4, 2010 I have also been digging around for info on diff/box variations for my 6-speed conversion. From what I understand, the diff you have would be fine (it is the smaller size casing?). Also, the effects of the different gear box/diff combinations can be checked here: gear ratio calculator Link to comment Share on other sites More sharing options...
jackso11 Posted August 4, 2010 Author Share Posted August 4, 2010 perfect. So I will use the original diff. the clutch in a v161 should be fine shouldn't it? I read that NAs had the v161 in aswell, I am guessing it had the same clutch as the TT with a v161 in though..? Link to comment Share on other sites More sharing options...
