Evil_Nuts Posted August 4, 2010 Share Posted August 4, 2010 Just bought a toyota oil filter and I'm gonna change oil, what grade can i use??? I only have excess to 5 30's, 10 40 or 0 20's.......should i just go buy some elsewhere??? Cheers Chris Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 4, 2010 Share Posted August 4, 2010 give opie-oils a call, very very helpful mate Link to comment Share on other sites More sharing options...
Neil-NA Posted August 4, 2010 Share Posted August 4, 2010 http://www.mkivsupra.net/vbb/showthread.php?t=56684 That should have all the info mate. Link to comment Share on other sites More sharing options...
Evil_Nuts Posted August 4, 2010 Author Share Posted August 4, 2010 I'm just at work with the car ramped up.......i have the repair manual telling me I can use 5w 30, 10w 30, 15w 40 or 20W 50................ Link to comment Share on other sites More sharing options...
JustGav Posted August 4, 2010 Share Posted August 4, 2010 I thought you had a master tech there who knew the toyotas? I go with 10-40w on an NA as that's what I get easily.... Link to comment Share on other sites More sharing options...
Evil_Nuts Posted August 4, 2010 Author Share Posted August 4, 2010 I thought you had a master tech there who knew the toyotas? I go with 10-40w on an NA as that's what I get easily.... We do.......Just wanted an opinion, Mines a BPU if that helps??? I have shit loads of 10w 40 but its not listed on the chart Link to comment Share on other sites More sharing options...
Kirk Posted August 4, 2010 Share Posted August 4, 2010 Personaly id go with motul 8100 X-cess 5w 40... Ive got a spare 6 litres you can buy Link to comment Share on other sites More sharing options...
Evil_Nuts Posted August 4, 2010 Author Share Posted August 4, 2010 Personaly id go with motul 8100 X-cess 5w 40... Ive got a spare 6 litres you can buy lol, how much dude? Link to comment Share on other sites More sharing options...
stevie_b Posted August 4, 2010 Share Posted August 4, 2010 I thought you had a master tech there who knew the toyotas? I go with 10-40w on an NA as that's what I get easily.... Same here, 10w-40 in a high mileage NA. You can use 5w-30 if you want: I think that's what Toyota workshops use, but it can weep out of high mileage engines a bit. Edit: just seen that you have a BPU (TT presumably), so I'd use 5w-30. Link to comment Share on other sites More sharing options...
Kirk Posted August 4, 2010 Share Posted August 4, 2010 Only what i paid for it myself Just dropped you a text Link to comment Share on other sites More sharing options...
Kev_A Posted August 9, 2010 Share Posted August 9, 2010 Ester synthetic Fuchs Silkolene Pro S from Opie oils, that's what I was using Link to comment Share on other sites More sharing options...
Guest Supra-T Posted August 9, 2010 Share Posted August 9, 2010 Ester synthetic Fuchs Silkolene Pro S from Opie oils, that's what I was using Same here! Link to comment Share on other sites More sharing options...
