bigjools Posted August 3, 2010 Share Posted August 3, 2010 radio stopped working looks like you have to remove plastics from around it or a diffrent way help plz dont what to break it Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 3, 2010 Share Posted August 3, 2010 Do what now? Link to comment Share on other sites More sharing options...
Supra N_A Posted August 3, 2010 Share Posted August 3, 2010 yes mate you have to take of all the pannels like the dash,gear surround im affraid. its pretty straight faward tbh... Link to comment Share on other sites More sharing options...
Attero Posted August 3, 2010 Share Posted August 3, 2010 You will have to remove the whole drivers dashboard. It's such an easy task. Just unscrew the top section and pull it all out bit by bit. You should spend probably 2-3 minutes max doing it. Link to comment Share on other sites More sharing options...
bigjools Posted August 3, 2010 Author Share Posted August 3, 2010 done it thanks all got sounds yer Link to comment Share on other sites More sharing options...
jonc Posted August 3, 2010 Share Posted August 3, 2010 search dashboard removal on here and follow instructions. It is dead easy once you have done it once:). Be carefull not to break any clips as that is when the dashboard starts to rattle;). I normally do it in this order: 1. Remove top cover (part where warning lights are held in by screws). Unclip wiring loom to both sets of warning lights 2. Unclip gear surround and unclip wiring loom to ashtray 3. Unclip main speedo/rev counter surround 4. Unclip left hand dash panel (this is the panel with the radio in) and unclip all wiring behind (AC, Heater, Clock, Ciggy lighter, maybe Anti skid and front lip wiring if you have them fitted) As said If you search on here you will find the full instructions. Be careful when storing your panels as the black rubber type finish can damage fairly easily. see simples Link to comment Share on other sites More sharing options...
jackso11 Posted August 3, 2010 Share Posted August 3, 2010 done it thanks all got sounds yer Eh? Link to comment Share on other sites More sharing options...
RCK10 Posted August 3, 2010 Share Posted August 3, 2010 Eh? The deciphered version: Done it. Thanks all. I have sounds now! Link to comment Share on other sites More sharing options...
