Goddamn lightbulbs!
neo2810
Arrgghh...
So I ripped my dash apart to try and replace the little bulb behind the aircon temp control only to find it's not the 286 type bulb I thought it was. It's a similar bulb but round at the bottom with longer conductor wires which then fit/wrap around the bulb holder so when fitted they make contact with the circuitboard.
I didn't notice any in Halfords, but then I wasn't really looking for that type.
Anyone know the part code for it?
Also, I couldn't find exact replacement bulbs for my dead internal rooflights (12v 8W round) so I grabbed a similar type which are same fit but bigger bulb glass and 12v 5W. I fitted both and the driver side works fine but the passenger side immediately burned out (clouded over white inside the glass). Is that likely to be a dud bulb or should I not be fitting 5W bulbs where 8W bulbs should be (as I understand it, that's just the light intensity)?
sounds to me like a dud bulb
the w is the watts and is how much power it would put through the cabling i.e.
5 watts / 12volts = 0.4 of an amp
8 watts / 12volts = 0.66 of an amp
The bulbs for the front indicator will be 7440 W21W (T20).
The bulb for the side is 501 W5W.
2 x T5 LED fitment (one for dash, other for Ignition barrel light)
3 x T10 fitment LED's
5 x T4 for the heater control
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 1156
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: H3-55W
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 194
Rear Sidemarker Light Bulb Size: 194
Glove Box Light Bulb Size: 37 or 74
Trunk/Cargo Area Light Bulb Size: 194 or DE3022
Instrument-General Light Bulb Size: 194 or 74
Edited by madwoody1
missed something (see edit history)
  • 3 years later...
