neo2810 Posted August 2, 2010 Share Posted August 2, 2010 Arrgghh... So I ripped my dash apart to try and replace the little bulb behind the aircon temp control only to find it's not the 286 type bulb I thought it was. It's a similar bulb but round at the bottom with longer conductor wires which then fit/wrap around the bulb holder so when fitted they make contact with the circuitboard. I didn't notice any in Halfords, but then I wasn't really looking for that type. Anyone know the part code for it? Also, I couldn't find exact replacement bulbs for my dead internal rooflights (12v 8W round) so I grabbed a similar type which are same fit but bigger bulb glass and 12v 5W. I fitted both and the driver side works fine but the passenger side immediately burned out (clouded over white inside the glass). Is that likely to be a dud bulb or should I not be fitting 5W bulbs where 8W bulbs should be (as I understand it, that's just the light intensity)? Quote Link to comment Share on other sites More sharing options...
madwoody1 Posted August 2, 2010 Share Posted August 2, 2010 (edited) sounds to me like a dud bulb the w is the watts and is how much power it would put through the cabling i.e. 5 watts / 12volts = 0.4 of an amp 8 watts / 12volts = 0.66 of an amp The bulbs for the front indicator will be 7440 W21W (T20). The bulb for the side is 501 W5W. 2 x T5 LED fitment (one for dash, other for Ignition barrel light) 3 x T10 fitment LED's 5 x T4 for the heater control Low Beam Headlight Bulb Size: 9006 High Beam Headlamp Light Bulb Size: 9005 Parking Light Bulb Size: 168 Front Turn Signal Light Bulb Size: 1156 Rear Turn Signal Light Bulb Size: 1156 Tail Light Bulb Size: 1157 Stop Light Bulb Size: 1157 High Mount Stop Light Bulb Size: Assembly Fog/Driving Light Bulb Size: H3-55W License Plate Light Bulb Size: 168 Back Up Light Bulb Size: 1156 Front Side Marker Light Bulb Size: 194 Rear Sidemarker Light Bulb Size: 194 Glove Box Light Bulb Size: 37 or 74 Trunk/Cargo Area Light Bulb Size: 194 or DE3022 Instrument-General Light Bulb Size: 194 or 74 Edited August 2, 2010 by madwoody1 missed something (see edit history) Quote Link to comment Share on other sites More sharing options...
neo2810 Posted August 2, 2010 Author Share Posted August 2, 2010 Cheers fella, that's spot on Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2010 Share Posted August 3, 2010 Great post madwoody1 Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 9, 2014 Share Posted April 9, 2014 Nice bit of info this Quote Link to comment Share on other sites More sharing options...
