Hub rings.
tbourner
I've got a set of hub rings that the pack say are 73mm external and 60.06 internal, but they are actually much bigger than that inside, so they flap about on the hubs!!!
They fit the wheels OK but that doesn't really help.
1. Any problems of running without them?
2. Anywhere I can get the right ones?
3. How much?
I might get shot down for this, but personaly I don't see any problem in running without them. If your wheel nuts are properly tightened (103Nm) then all they are used for is the initial alignment.
The torque is transmitted through the friction between the hub face and the wheel face, NOT through the wheel studs as some people think (the same way that camshafts are driven on the friction surfaces and not on the aligning dowel or keyway.
Cant wait for Chris to see the last reply:complain: nothing personal Digsy:littled:
Contact Ibra at proalloys he has a supplier for rings, or import them form the US. Ibra has got a couple sizes for me for a variety of projects@ £2-00 to £3.00 each
The big problem is you can not be sure that the bolt holes will pull the wheel central.
If bolts should come loose, unusual I know , but if they did yoiu are totally screwed and any other unfortunate road user who gets in your way.
For what it costs I say fit them and stay safe.
Same with the large I section beams in these sky scrapers, the bolts pull the mating surfaces together but the friction between the girders holds them in place.
The bolts are subjected high tensile forces and very little shear!
Best to have the rings though so the wheel nuts can be located easier which will also prevent hole elongation. Especially important when some idiot is putting your wheels on too tight with an air gun.
