One stop shop needed
Guest Suprastar2009
Guest Suprastar2009
Hi Guys I need a few things doing on the Supra and wondered if anyone knows of anywere that can do the whole lot in one go and what sort of cost?
Jobs are as follows:
Check rear brake callipers for sticking and potential disc and pad change.
Fit Hydraulic handbrake
Fit navigator foot well
Change standard power steering resevoir for chrome one
Change header tank to chrome version and change pipes to red ones supplied.
Fit Carbon Aerocatches to carbon fibre bonnet.
Note all parts will be supplied apart from power steering fluid and rad fluid
Guest Suprastar2009
Its a lockable type that holds the car, and im only asking for a cost to fit, dont panic guys. The reason is im getting one free from a new sponsor along with the navigator foot rest and header tank, I dont have to fit it I was just considering it.
Guest Suprastar2009
They don't pass mot's, you have to have a hand brake tha tholds it self.
Youve got my head ticking over now, would it still fail the MOT if it is lockable? :search:
When the hell are you going to use a hydro ??? Why would you even have one a road car lol, I would even argue why you would want one on a drift car if it has a caliper handbrake lol......
And WTF is a navigator foot well thingy ?
I dont think a hydraulic brake will pass the MOT but I will go round and check in the morning, it MAY be ok if the fluid reservoir is seperate to main fluid reservoir
Guest Suprastar2009
Hi yeh it has a seperate .700 master cylinder in the kit this can be changed thought to either .625 or .750 I will call you in the morning to discuss. :)
Guest Suprastar2009
The hydraulic system uses most of the parts from the origional system already in the car would this count as mechanical back up? I assumed that the separate master cylinder means that it has back up fromnthe standard one which is used in conjunction
I have no idea, I see them on rally cars, but they either have a separate parking brake by cable system, or they don't worry about most of the construction and use regulations, or whatever they are called this week :) You would need to phone one of the government bodies and ask giving specifics. Good luck, unnecessarily talking to government bodies is something I have spent the last 40 years trying to avoid ;)
