Guest brko Posted August 2, 2010 Share Posted August 2, 2010 hi guys I need help with my fuse Under the Hood!!!! I seem to be missing about 7 of them and Im not sure what all of them do and if I do need them. If any of you can check yours and see if you are missing some aswell then we can see if we need them or not. I was missing them since i got the car which was about 2 years ago, but i just dont know if i need them or not. If yes then please advise which one and if you know explain what they do. Below the pictures from the fuse box(shows the name of the fuses) and a pic of the (actual fuses), which you can see in RED which iam missing Thanks for your time guys allways the BEST!!!!:) Quote Link to comment Share on other sites More sharing options...
Guest brko Posted August 2, 2010 Share Posted August 2, 2010 Also my car is a JAP SPEC import:blink: Quote Link to comment Share on other sites More sharing options...
colmcork Posted August 2, 2010 Share Posted August 2, 2010 I just checked mine there mate and i am missing the fuse marked 30 amp abs 2, all the rest are in place. My car seems to be running just fine without it though. It is a 1995 j-spec tt auto. Quote Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2010 Share Posted August 2, 2010 Just going on memory here, but the following are not used on Jspec TT's: - EFI 2 30a Fuse - EFI 2 Relay - ABS 2 fuse Can't recall what the others are for right now, but have a feeling at least one is not used. Is your's an NA by any chance? If it is then it will explain why quite a few other others are missing. Quote Link to comment Share on other sites More sharing options...
Guest brko Posted August 2, 2010 Share Posted August 2, 2010 Mine is Jspec N/A Auto Im missing both fuses for abs, does that mean that my abs doesnt work?? In the past when i brake suddenly the brakes i think lock up and the car slides edpecially in rain. Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 3, 2010 Share Posted August 3, 2010 It probably means your car doesn't have ABS! I think mine is the same. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted August 4, 2010 Share Posted August 4, 2010 (edited) Generally on cars, it's normal for several fuses to be "missing" in the fusebox. The car manufacturer uses a single mould for the fusebox whether it's a top-of-the-range car with all the toys, or the basic model. I can't quite see from your photos, but you can ignore any fuse slots that don't even have the female contacts present. Edited August 5, 2010 by stevie_b typo (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest brko Posted August 4, 2010 Share Posted August 4, 2010 Very strange that any Supra doesnt have abs??!?? Anybody else with Jspec N/A Auto that can check if 7 fuses shown in the pics are missing Quote Link to comment Share on other sites More sharing options...
JODY T Posted August 4, 2010 Share Posted August 4, 2010 Question: does everything you can think of work? If so then no news to worry about fuses.. As the circuit needs them to make things work.. Quote Link to comment Share on other sites More sharing options...
n boost Posted August 5, 2010 Share Posted August 5, 2010 If u need any, i have some in the for sale section. Quote Link to comment Share on other sites More sharing options...
