Kevin Huntley Posted August 2, 2010 Share Posted August 2, 2010 I have forsale a set Mickey Thompson ET Streets 28-12.50-15 which are brand new. These were the tyres I was going to use for the next Drag racing season until I ran out of money and had to retire from the sport. These are the daddy of all tires for those who seriously want to improve their times. They offer a fantastic foot print for the best 60ft time and due to them being so tall increase your trap speed over the line. These sell for around £180 each I looking for £275 for the pair delivered. Thanks for looking Kevin Link to comment Share on other sites More sharing options...
dude Posted August 2, 2010 Share Posted August 2, 2010 Kevs right, these tyres are the daddy Link to comment Share on other sites More sharing options...
T2 MSW Posted August 2, 2010 Share Posted August 2, 2010 mmm tempting, if only you had some rims too Not sure I can be bothered going to the extent of fitting Jspec rears though. Link to comment Share on other sites More sharing options...
dude Posted August 3, 2010 Share Posted August 3, 2010 mmm tempting, if only you had some rims too Not sure I can be bothered going to the extent of fitting Jspec rears though. Dude these will hook up like you won't beleive, it only takes 20 mins to swap brakes, you could be extra flash and fit a dry break coupling on the rear lines but to be honest i don't notice a lot of difference between J spec rears and UK especially when using Chris Willson's pads in the rear. I would buy em myself but they do not comply with the regs of my HKS class, TOTB say you can't use em but they always seem to turn a blind eye. Link to comment Share on other sites More sharing options...
Kevin Huntley Posted August 3, 2010 Author Share Posted August 3, 2010 Dude, which class are you planning on running in? I used the smaller sizes of these in the street series at Pod and they hooked up great. I was sure this tire combo was going to take me into the mid low 9's. Dude these will hook up like you won't beleive, it only takes 20 mins to swap brakes, you could be extra flash and fit a dry break coupling on the rear lines but to be honest i don't notice a lot of difference between J spec rears and UK especially when using Chris Willson's pads in the rear. I would buy em myself but they do not comply with the regs of my HKS class, TOTB say you can't use em but they always seem to turn a blind eye. Link to comment Share on other sites More sharing options...
dude Posted August 3, 2010 Share Posted August 3, 2010 Dude, which class are you planning on running in? I used the smaller sizes of these in the street series at Pod and they hooked up great. I was sure this tire combo was going to take me into the mid low 9's. Im in the street class Kev, I was pretty sure the rules exclude 'wrinkle' wall tyres and say they must be radial. Link to comment Share on other sites More sharing options...
JamieP Posted August 3, 2010 Share Posted August 3, 2010 Tempting but i hear they can be dangerous unless you run skinney front wheels? Link to comment Share on other sites More sharing options...
DARETT Posted August 3, 2010 Share Posted August 3, 2010 Yup, bias ply and a radial doesn't work well especially when running good power like yours. Link to comment Share on other sites More sharing options...
dude Posted August 4, 2010 Share Posted August 4, 2010 Yup, bias ply and a radial doesn't work well especially when running good power like yours. Plenty of people dissagree on that one but can't say im to keen to prove the point one way or another. Link to comment Share on other sites More sharing options...
DARETT Posted August 4, 2010 Share Posted August 4, 2010 Yup they do indeed, wouldn't want to prove the point either with your power. Over 700hp you don't want alot of traction at the front if you need to correct the car. Link to comment Share on other sites More sharing options...
Kevin Huntley Posted August 4, 2010 Author Share Posted August 4, 2010 Strange, they must have changed the rules since I was running. They used to be on the approved list of tyres and were both MOT and DOT approved. Im in the street class Kev, I was pretty sure the rules exclude 'wrinkle' wall tyres and say they must be radial. Link to comment Share on other sites More sharing options...
Kevin Huntley Posted August 4, 2010 Author Share Posted August 4, 2010 Jamie, I think unless you change your tyres to ET Streets or similar you are not going to acheive your goals. Drag Radials at Pod will either result in wheel hop or breakage. They do also do 17" skinnies which can be used with big brake conversions, was reading about the recently on SF. You could just swap me your BBK for the skinnies and my brake set up plus cash your way. Tempting but i hear they can be dangerous unless you run skinney front wheels? Link to comment Share on other sites More sharing options...
Kevin Huntley Posted August 4, 2010 Author Share Posted August 4, 2010 Just checked the rules for the street class and they state: All tyres must be E marked or DOT legal & remain road legal through the duration of the event, displaying 1.6mm of tread after the run over 3/4 of the tread pattern So I guess they can be used. Found this on the MT Website: Worlds Fastest D.O.T. Class Race Tire. World's Fastest D.O.T. class race tire. Same great features as our race winning ET Drag with a D.O.T. stamp that meets the rulebook specifications for street tire classes. Tube type for extra sidewall strength, better air retention, and more consistent ET’s. ■D.O.T. Approved ■Compounded For Maximum Traction ■Requires Little or No Burnout ■Engineered For Consistent Performance Link to comment Share on other sites More sharing options...
dude Posted August 4, 2010 Share Posted August 4, 2010 I will check the rules later Kev, they are on the banned list at TOTB but are always so far allowed to run. Link to comment Share on other sites More sharing options...
Kevin Huntley Posted August 9, 2010 Author Share Posted August 9, 2010 Bump for anyone who wants to run a good time at Supra Pod! Link to comment Share on other sites More sharing options...
Kevin Huntley Posted September 15, 2010 Author Share Posted September 15, 2010 BUMP, open for offers need to clear some space in the garage. Link to comment Share on other sites More sharing options...
JamieP Posted December 5, 2010 Share Posted December 5, 2010 BUMP, open for offers need to clear some space in the garage. Still got these Kev? sent you a pm. Link to comment Share on other sites More sharing options...
