flyby Posted August 1, 2010 Share Posted August 1, 2010 Hi all. Whare du i start looking for my problem. When I accelerate car is changes direction(left), and when I move my foot away from the speeder it do it again, but to right. Is it the upper og lower arms in the back, or another thing ? Link to comment Share on other sites More sharing options...
Homer Posted August 1, 2010 Share Posted August 1, 2010 Is it the front or rear that's trying to change direction? Have you checked the basics like tyre wear and pressures? Suspension Geometry? Link to comment Share on other sites More sharing options...
Dnk Posted August 2, 2010 Share Posted August 2, 2010 (edited) As Homer says check the basics first such as tyre condition + pressures. Then I'd pop the car on a ramp and do a bolt check and check for play in all the suspension joints . Then i'd have a full suspension geometry check done Edited August 2, 2010 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
flyby Posted August 10, 2010 Author Share Posted August 10, 2010 hi I have some adjustment on suspension geometry, and when back be cores it did not do the job. But after a month it was still perfect. We checked tyres and pressure, also OK. It is hard to tell, if it is back or front I think. Link to comment Share on other sites More sharing options...
Ian C Posted August 11, 2010 Share Posted August 11, 2010 It's probably your rear left tyre is low on pressure. Link to comment Share on other sites More sharing options...
flyby Posted August 11, 2010 Author Share Posted August 11, 2010 It's probably your rear left tyre is low on pressure. Hi We checked tyres and pressure,was also OK Link to comment Share on other sites More sharing options...
