Lude Posted August 1, 2010 Share Posted August 1, 2010 have found the guide to removing, but think its the USA one as the ABS and other parts are on the other side? http://mkiv.com/tmp/no_charcoal_canister/ anyway, do you have to join any pipes together? isnt it a case of disconecting them all, removing the canister, then just blocking the 1 that goes to the manifold? (the vacuum) or are there other things which need doing? Quote Link to comment Share on other sites More sharing options...
hodge Posted August 1, 2010 Share Posted August 1, 2010 Block off the pipe that runs round the back of the engine to the turbo pipes. Block off or remove the pipe that runs along the side of the plenum. The third pipe, if you want it super tidy, just bend it down to vent under the car, remove the canister and the bracket. Quote Link to comment Share on other sites More sharing options...
Bossco Posted August 2, 2010 Share Posted August 2, 2010 LOL Hodge. Funny seeing you posting about charcoal canister removal. Quote Link to comment Share on other sites More sharing options...
hodge Posted August 2, 2010 Share Posted August 2, 2010 LOL Hodge. Funny seeing you posting about charcoal canister removal. Erm why lmao. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted August 11, 2012 Share Posted August 11, 2012 Block off the pipe that runs round the back of the engine to the turbo pipes. Block off or remove the pipe that runs along the side of the plenum. The third pipe, if you want it super tidy, just bend it down to vent under the car, remove the canister and the bracket. Old thread revival and i know its been talked about in another threads but i just want to confirm with it first before i start it. Quote Link to comment Share on other sites More sharing options...
