Headlight level switch fitting
Wyntersun
I have a new set of uk glass head lights fitted with the headlight adjustment motor attached at the back.
How difficult would it be to retro fit the headlight level adjustment switch to make them work?
Has it been done and what do you need other that the headlights and level switch?
Thanks
Thanks
Not overly difficult if you have bits of the loom, it is a basic circuit. The hardest part would probably be getting the connectors and putting the switch in the dash.
