Wyntersun Posted July 30, 2010 Share Posted July 30, 2010 I have a new set of uk glass head lights fitted with the headlight adjustment motor attached at the back. How difficult would it be to retro fit the headlight level adjustment switch to make them work? Has it been done and what do you need other that the headlights and level switch? Thanks Link to comment Share on other sites More sharing options...
JustGav Posted July 30, 2010 Share Posted July 30, 2010 I have a new set of uk glass head lights fitted with the headlight adjustment motor attached at the back. How difficult would it be to retro fit the headlight level adjustment switch to make them work? Has it been done and what do you need other that the headlights and level switch? Thanks Not overly difficult if you have bits of the loom, it is a basic circuit. The hardest part would probably be getting the connectors and putting the switch in the dash. Link to comment Share on other sites More sharing options...
Wyntersun Posted July 30, 2010 Author Share Posted July 30, 2010 I don't mind fitted the plug in the dash as im looking at buying a uk spec panel so I can fit an oem fog switch and headlight level switch. I guess a I could use mini spade connectors to attach to the pins. Link to comment Share on other sites More sharing options...
