suprafreak123 Posted July 29, 2010 Share Posted July 29, 2010 Hi guys + girls Just interested in how you can use the seatbelt tags to identify year of supra, Can you lot decode what I should look for? Thank you Link to comment Share on other sites More sharing options...
suprafreak123 Posted July 29, 2010 Author Share Posted July 29, 2010 .. Link to comment Share on other sites More sharing options...
nigelboyne Posted July 29, 2010 Share Posted July 29, 2010 mate i never heard of this maybe your not making it clear Link to comment Share on other sites More sharing options...
suprafreak123 Posted July 30, 2010 Author Share Posted July 30, 2010 i was told you could use the seatbelt tags to find out the year of the supra? Link to comment Share on other sites More sharing options...
mawby Posted July 30, 2010 Share Posted July 30, 2010 Every seat belt tag has a year of manufacture on it that is normally the same year as the car was manufactured. It's not 100% reliable for several reasons but it can be used to identify a car advertised as being much newer than it really is. If you want to know the year & month your Supra was made it's much better to put the frame number into the EPC and it will tell you. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 30, 2010 Share Posted July 30, 2010 Decode it? It should just have a month/year printed on it. As Mawby said its not 100% reliable as they can of course get changed, but if you check all the belts out you should get your answer as at least some of them will match up Link to comment Share on other sites More sharing options...
suprafreak123 Posted July 30, 2010 Author Share Posted July 30, 2010 what EPC? Link to comment Share on other sites More sharing options...
Nic Posted July 30, 2010 Share Posted July 30, 2010 Get the Frame Number off the VIN plate and go HERE to the 'Japanese Supra Chassis Production Numbers' section. Link to comment Share on other sites More sharing options...
suprafreak123 Posted July 30, 2010 Author Share Posted July 30, 2010 how accurate is the result from the frame number? Link to comment Share on other sites More sharing options...
mawby Posted July 30, 2010 Share Posted July 30, 2010 how accurate is the result from the frame number?PM me your model code (i.e. JZA-80-ALPZZ) and your frame number (i.e. JZA80-1234567) and I'll look it up in the actual EPC. It's 100% accurate as it's the information Toyota use for supplying parts. Link to comment Share on other sites More sharing options...
Paul Posted July 30, 2010 Share Posted July 30, 2010 Pull the ashtray out and there will be a moulding date stamp, giving month and year. Link to comment Share on other sites More sharing options...
DodgyRog Posted July 30, 2010 Share Posted July 30, 2010 Or you could do it yourself here http://www.mkivsupra.net/vbb/showthread.php?t=41702 then print off the results for future reference, thats what I did anyway Link to comment Share on other sites More sharing options...
Nic Posted July 31, 2010 Share Posted July 31, 2010 how accurate is the result from the frame number? 100% Link to comment Share on other sites More sharing options...
