Garage Clearout - Stock and Aftermarket
Wez
Hey All,
Been clearing out the garage, here is a collection of stock and aftermarket parts from a 1996 jspec TT6.
* Stock Door Control Unit £30
* Stock Fuel Rail £10
* Stock RZ Sway Bars £40
* Stock Throttle Body Traction Motor & Sensor £15
* Stock Double-Din Stereo & Band Expander £offers
* AC Amplifer Unit £30
* Brown Electric Aerial box £10
* Lower Glove Box £35
* Door Seal Trims £20
* 2 x Rear Wiper Motor £10 each
* Rear Hatch Glass (untinted) £25 SOLD - pending payment
* NGK Iridium BKR8EIX Plugs (6 x used) £25 SOLD
* Rear Suspension Trim £10 SOLD
* Stock door wiring looms with electric mirror wiring £35 SOLD
* Stock Boot Blind £25 SOLD
* Stock Throttle Body £50 SOLD
* Enkei 17" Wheels (clear UK brakes) £100 SOLD
* FSE Fuel Regulator £30 SOLD
* Polished Breather Tank £25 (delivered UK) SOLD
* Front Driver Door Mechanism/Motor £20 SOLD
* AC Pump/Compressor £45 SOLD
* Stock Seats (drivers electric) £offers SOLD
* Front Drivers Door Glass £50 SOLD
* 17" Wheel Centers £20 SOLD
* Trac Off Switch £5 SOLD
* Electric Mirror Controls £5 SOLD
* A-Pillar Trims (holes for gauge pod/no handle) £15 SOLD
* Steering Wheel Boss (whifbitz) £50 SOLD
* Veilside Side Skirts £100 SOLD
* Seatbelt Rear Clips £10 SOLD
* TT6 Clocks £100 SOLD
* Passenger Window Switch £offers SOLD
* Walbro Fuel Pump £60 SOLD
* Apexi EL EGT Gauge (needs probe) £35 SOLD
* Stock 440cc Injectors £50 SOLD
* Stock Boost Control Solenoid £25 SOLD
* Stock Steering Wheel (no center) £10 SOLD
* Dash Blanks £10 SOLD
* Stock BOV £20 SOLD
* Stock AFR Sensor £20 SOLD
* Battery Tray £15 SOLD
* Stock TT MAP Sensor £25 SOLD
* Stock VSVs £35 SOLD
* Stock Water Neck £20 SOLD
* Heater Controls £35 SOLD
* Stock JSpec Fuel Pump £20 SOLD
* Stock Fuel Regulator £35 SOLD
* Clock £offers SOLD
  • Replies 147
Sorry to be a pain Wez, but the A-pillar with "pod cut-out", I would like to see a pic, and could you measure the size of said cut-out.
If its the right size or smaller, I'll take it.
Thank you.
It doesnt have cutouts, its the stock A-Pillar unit with two screw holes where a two gauge pod was mounted to it.
Its a fuel regulator so has no direct influence on power.
I will measure the pipes and post up in a bit.
how much power does can that fse regulator run and what size are the pipes in and outlets?
Thanks
Gary
