Some diff advice please
hodge
Keep an eye on the US Supraforums? Surely if a lot of them are carrying out projects with big V8 swaps and similar they'll be chopping and changing diffs and the like?
You'll get for a good price from there too I'd imagine?
check out supraforum.com, they come up a lot more often over there but sell for around $1500.
Not cheap stateside unfortunately, glad i got a spare when i did:p
So if a 6spd TT pumpkin came up, the only other part needed would be the appropriate TRD LSD?
Yeah, MVP sell them brand new and complete with stock lsd installed.
Toyota OEM Differential Carrier Assembly for 1993-98 Supra TT 6spd
Part # To 41110-14780
Are you doing a swap from a non-turbo or an Auto TT to the 6spd V160 twin turbo? Or, maybe you have a 6spd TT and your "pumpkin" exploded because you didn't have our Majestic CNC Billet Differential Cover?
If either of the above describe you, then likely you need this new Toyota Differential Carrier Assembly, also known as a pumpkin.
The price includes the entire assembled unit with a new Toyota differential already installed. You just drop this in and you're done, unless you prefer a TRD LSD. Unfortunately these units are not available with the TRD LSD pre-installed, so that would have to be a separate purchase.
MSRP $3,557.39
Your Price $2,668.00
Got a feeling I'm gona need driveshafts too.
If I'm gona retrofit some TT abs sensors for the solaris trac control I'll need some driveshafts anyways as I think the abs sensors are mounted on them unless someone can correct me.
If you get just a case i have a stock 30k lsd about somewhere you can have, its either in my shed or at Lee's.
Really.......
How much of a legend are you then thanks very much.
I'll start looking for a pumpkin asap.
Cheers Jamie.
Correct, the ABS rings are on the driveshafts, it may be possible to retro fit but not sure if anyone has tried.
Well I love a challenge Wez.
I would havecthought the solaris will just need a pulse feed from each wheel to make the trac control work I'm sure RLTC uses this idea. I can't see it being too hard to do.
