Guest Jonny L Posted July 27, 2010 Share Posted July 27, 2010 Hi Guys, I have a problem with my active spoiler. Sometimes not everytime when you first start the car after a minute say the active spoiler go's up and down intermittently and the handbrake light (!) illuminates as though there is a problem. Is there a sensor that that might be broke. Any advice would be greatly appreciated John Quote Link to comment Share on other sites More sharing options...
Nic Posted July 27, 2010 Share Posted July 27, 2010 (edited) Sounds like there is a wire shorting somewhere, it *may* have something to do with the speedo conversion, as the spoiler is speed sensitive. Other guess is fault with either the button, spoiler control unit or bad connection to either. The control unit for the spoiler is mounted above the stereo, behind the dash panel. Edited July 27, 2010 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
jackso11 Posted July 27, 2010 Share Posted July 27, 2010 are you repeatedly tapping the button at the same time? that could cause it Quote Link to comment Share on other sites More sharing options...
VIL Posted July 27, 2010 Share Posted July 27, 2010 I think its a speed controller related issue, you will find that when driving it also plays up making the warning light come on...can be unnerving!!! The simple, cheap and effective short term solution....turn it off Quote Link to comment Share on other sites More sharing options...
Guest Jonny L Posted July 27, 2010 Share Posted July 27, 2010 Hi guys, the car is a uk spec so it was fitted as standard. It is very intermittent but usually only occurs when the car is idling or at low speeds, or sometimes not at all. How will I find out if is the control unit? and are the expensive to replace? John Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted July 27, 2010 Share Posted July 27, 2010 Might just be a bit of damp, it sounds similar to what happened to mine for about a 2 week period on and off, it seemed to get confused when parked up about deploying, always worked on the move, but its fine again now!? Quote Link to comment Share on other sites More sharing options...
