Lots of items (amps/tools/cleaning,waxing products)
Gamer
Having a clean out before the move to the States, thought I would post some of this stuff here before I put them on eBay.
Open to offers on everything, it all has to go. Collection is preferred (Heathfield, East Sussex), postage can be arranged for most items apart from the jack and tool chests which are too heavy/bulky.
Kenwood KAC-PS811D single channel power amplfier (SOLD)
Condition: Good, some small marks and needs a little clean but otherwise in good visual order. Missing screws for faceplate, easy fix. 100% working unit.
# 1600W Max. power output
# 1 ohms RMS power output 1 x 1000W
# 2 ohms RMS power output 1 x 800W
# 'D' class amplifier
# Line output
# Integral cooling fan
# Amp to amp connection via S-Video cable (optional extra)
# New Kenwood amplifier control system for treble / bass / Q-factor / gain
# New Kenwood display of voltage / current / temperature / fan speed
# Low pass filter 50 - 200 Hz
# Infrasonic filter 15Hz / 25Hz
# Phase switch
# Band reject filter
# Dimensions (WxHxD) : 386 x 61 x 260 mm
http://img843.imageshack.us/img843/2729/dscf0950p.jpg
http://img529.imageshack.us/img529/5897/dscf0947.jpg
Kenwood XXV-02A power amplifier (limited edition)
Condition: very good, some very slight marks. 100% working unit, comes with all documentation.
Both single-channel and four-channel 25th anniversary amplifier models boast the highest sound quality thanks to carefully selected components in packages with a stylish deep-black finish.
Keynotes are the special 25th anniversary capacitors, LAPT power transistors with superior high-frequency characteristics and LSI circuits, all mounted on glass epoxy PCBs. The result is the very finest in sound quality.
Amplifier features specially developed 25th anniversary super-filtering capacitors. Specially selected after extensive testing to provide the best matching, the electrolytic capacitors in this model feature drastically improved leak current characteristics to provide higher audio quality over a longer life and allow more natural sound reproduction that is ever-closer to the original.
* High quality glass-epoxy printed circuit board features larger circuit tracks than conventional designs to allow greater current handling capacity and assure stable power output. Improved circuit layout enhances frequency response characteristics and greater board rigidity serves to improve audio quality
* High-speed output LAPT power transistors operate over an extremely wide frequency range, generating minimal distortion even at high currents
* Max power output 960 watts
* Blue top-mounted LED display can be set to display any of the following information:
o Voltage: indicates the source voltage
o Current: indicates the current consumption
o Temperature: indicates the internal temperature
o Fan: indicates the rotation speed of the cooling fan in 3 steps: Fast, Slow, or Off
* Amp control system allows amplifier functions to be controlled by compatible head units
* Computer controlled cooling fan
* Detachable aluminium dress plate removes to reveal top control panel
* Built-in parametric EQ control of Bass & Treble frequency / Gain control / Bass Q factor
* Built-in low variable low-pass filter on B channel 50 - 200Hz (24dB/oct)
* Built-in variable high pass filter on A/B channels 50 - 200Hz (12dB/oct)
* Built-in infrasonic filter 15Hz (24dB/oct). Ultra-low frequencies that cannot be reproduced by a subwoofer do not become sound but become unnecessary oscillations, which affect sound by causing distortion. These frequencies also waste amplifier power and can cause damage to speakers. Setting the Infrasonic filter switch to 15Hz cuts signals below this frequency eliminating harmful distortion and protecting speakers
* Gold-plated RCA line input / output terminals
* Dimensions (WxHxD) : 446 x 61 x 260 mm
# 88 watts RMS x 4 at 4 ohms (124 watts RMS x 4 at 2 ohms)
# 240 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
# variable high- and low-pass filters (50-200 Hz, 24 dB/octave low-pass, 12 dB/octave high-pass)
# subsonic filter for rear channels (0/15 Hz, 24 dB/octave)
# AMS (Amplifier Management System): -15 to 15 dB bass level control, Q factor control, bass/treble frequency control
# aluminum electrolytic capacitors
# high-speed Linear Amplitude Power Transistors (LAPT)
# cooling fan
# LED status display (voltage, current, temperature, fan speed)
# CEA-2006 compliant
# preamp outputs
# Tri-way capable (Tri-Way Crossover required)
# 2-, 3-, or 4-channel output
# fuse rating: 30A x 2
# 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
http://img507.imageshack.us/img507/2413/dscf0956.jpg
http://img44.imageshack.us/img44/9104/dscf0952q.jpg
More stuff to follow in next post....
Reverie Volcane V2 automotive fire extinguisher (Sold)
Aluminium alloy bodied fire extinguisher rated for automotive fires Supplied with Black Anodised cage, pressure gauge and handles Finish: Black Anodised. Charge Type: 0.9 litre AFFF
http://a.imageshack.us/img705/5963/dscf0959x.jpg
Silkolene PRO S 10W-50 Ester Synthetic Oil For High Performance Engines
(Sold)
Silkolene Pro S is simply one of the best quality engine oils there is! It's an ester based fully synthetic motor oil created to meet the most demanding use.
Silkolene Pro S is available in 3 different viscosity grades - Pro S 5W/30, Pro S 10w/50 (this product) and Pro S 5w/40. Silkolene Pro S 10W/50 is particularly recommended for use in warmer ambient temperatures.
Silkolene Pro S is suitable for use in all modern cars and is particularly recommended for high performance engines. The full synthetic base fluid ensures that the products are thermally stable and extremely resistant to oxidation, even when stressed to the extremes of endurance.
The excellent overall performance profile ensures optimum protection even in the most demanding turbo-charged power units in modern performance cars. The discerning motorist may be confident that the products excel in all areas of performance and ensure maximum protection under all operating conditions.
http://img840.imageshack.us/img840/7468/dscf0960.jpg
MOTUL - RBF600 Racing Brake Fluid - 500ml x 2 (one has been opened and just a tiny bit was used)
100% synthetic, RBF 600 FACTORY LINE is a polyglycol-based brake fluid exclusively designed for races. Developed to resist high temperatures and wet-weather conditions, RBF 600 has a high dry boiling point of 312°C and a wet boiling point of 216°C. This ensures effective braking under extreme racing or rainy conditions. Couple this with its outstanding anti-vapor lock performance, RBF 600 has become a well-trusted brake fluid in many races.
http://img826.imageshack.us/img826/3458/dscf0963.jpg
TRW/LUCAS DOT 5.1 brake fluid: 1 litre
http://a.imageshack.us/img638/6032/dscf0965b.jpg
Mistral Methanol - 5 litre
(perfect for those of you running water injection)
http://a.imageshack.us/img691/6600/dscf0968h.jpg
Wolf Power BC50 Battery Charger
* Input voltage: 230v
* Charging current: 50 amps
* Absorbed current: 6 amps
* Rated wattage: 1400w
* Charging voltage: 12v
* Weight: 11 kgs
http://a.imageshack.us/img191/1197/dscf0969j.jpg
P21s Wax, Paintwork cleaner and Polishing soap (Sold)
(soap was used once, Wax & Paintwork cleaner is new and unused)
Excellent wax, read about the products here: http://www.p21s.com/
http://img266.imageshack.us/img266/381/dscf0971.jpg
P21S, Sonax,Meguiars,Zymol (Sold)
P21S Carnauba Wax (half full)
P21S Paintwork Cleaner (half full)
Sonax liquid wax (half full)
Zymol cleaner wax (half full)
Meguiars NXT Spray wax (almost full)
http://a.imageshack.us/img341/9792/dscf0972b.jpg
Autoglym (Sold)
Leather care cleaner (3/4 full)
Car glass polish (half full)
Bumper care (half full)
Tar remover (half full)
http://a.imageshack.us/img716/1039/dscf0973.jpg
Trust (Greddy) GREX Oil cooler adapter plate with earls fittings (Sold)
http://img295.imageshack.us/img295/9851/dscf0978.jpg
http://img838.imageshack.us/img838/7818/dscf0977.jpg
Real Carbon fibre fuse cover (purchased from MVP) (SOLD)
Slight damage as shown in picture but otherwise in overall good condition
http://img62.imageshack.us/img62/5782/dscf0982d.jpg
http://img132.imageshack.us/img132/3839/dscf0984o.jpg
Small overflow tank (perfect for FMIC installs)
http://img820.imageshack.us/img820/1427/dscf0985h.jpg
http://img217.imageshack.us/img217/9492/dscf0986a.jpg
Draper General Tool Roller Cabinet & Tool Chest + Tools (Sold)
Comprises combined roller cabinet chest (size 616 x 330 x 1080mm) with Hammer Drill and a selection of popular hand tools, listed below.
• Chisel and punch set
• Circlip plier set
• Combination pliers
• Combined MM /AF Silverdrive socket set
• Crimping tool
• Curved jaw self grip pliers
• Diagonal side cutter
• Digital automotive analyser
• Drill and accessory kit
• Flat file & handle
• Flexible magnetic pick up tool
• Flexible shaft inspection mirror
• Hacksaw frame and blades
• Half round file & handle
• Halogen hand lamp
• Hand riveter kit
• Feeler gauge set
• Junior hacksaw and blades
• Latex gloves (large - pack of 10)
• Long nose pliers
• Long reach plier set
• Magnetic parts bowl
• Measuring tape
• Mechanics screwdriver set
• Metric combination spanner set
• Multi tool
• Pry bar set
• Ratchet torque wrench
• Round file & handle
• Rubber mallet
• Tinmans shear
• Trimming knife & 5 spare blades
• Two adjustable wrenches
• Mechanics bit set
• Draper TX-STAR tamperproof screwdriver set
• Waterpump pliers
• Wire scratch brush
Also comes with two magnetic fender guards
Most items are unopened. Some (not all) items are pictured below. I can provide more pics if needed. I can also provide stock codes for all items.
http://img225.imageshack.us/img225/3699/dscf0989.jpg
http://img412.imageshack.us/img412/2733/dscf0991.jpg
http://img820.imageshack.us/img820/3804/dscf0990.jpg
http://img835.imageshack.us/img835/9708/dscf0988.jpg
http://img638.imageshack.us/img638/1734/dscf0993b.jpg
http://img829.imageshack.us/img829/8448/dscf0994.jpg
http://img137.imageshack.us/img137/7284/dscf0997z.jpg
http://img812.imageshack.us/img812/3972/dscf1004.jpg
http://img716.imageshack.us/img716/9062/dscf1006.jpg
http://a.imageshack.us/img231/387/dscf1013y.jpg
Omega Magic Lift 2 ton Low profile jack (SOLD)
In good overall condition, some scratches and such. 100% working
* Extra long low side frames designed for long reach under the car chassis
* Innovative design of Magic Lift offers a quick lift for professional performance
* Wide stance and low center of gravity provides optimum stability under load stress
* Universal joint release mechanism provides precision control of load descent in any handle position
* Exclusive designed breather plug eliminates air in the hydraulic system, optimizing jack performance
Extra low, easily fits under the lowest Supra ;)
http://img823.imageshack.us/img823/6554/dscf1016y.jpg
http://img835.imageshack.us/img835/3842/dscf1017.jpg
Can you PM me the price you want for the carbon fibre fusebox cover?
Many Thanks
Dan
Hi Dan, already sold, sorry mate.
How much do you want for the draper tool set?
I paid close to £400 for the set. Looking for around £250 collected.
