Another Container From Japan..SAVE ££££ on freight
Jurgen-Jm-Imports
tell your friends in other forums if they need anything large fitted inside
you want to fill some engines in ?? look here
http://jmimports.mine.nu:10100/index.php?model=384&parts=135&mode=1&Submit=Search
supra boxes look here
http://jmimports.mine.nu:10100/index.php?model=232&parts=183&mode=1&Submit=Search
performance parts or other bits
http://jmimports.mine.nu:10100/index.php?model=384&parts=9999&mode=1&Submit=Search
alloy wheels
http://jmimports.mine.nu:10100/index.php?model=419&parts=9999&mode=1&Submit=Search
as an idea...
i will rent out a space in my container for £150 for a set or rims..(if you buy more than 5 items 100)
freight for rims is normally over £500
also if you want something bought in japan and its not listed here..send me the web address and link of the part and we will buy it and fit in the container for you...
i will not be making profit on the parts you BUY in JAPAN..
my profit is YOUR FREIGHT...
which am giving out at a cheap rate..
pics of last container
Edited by Jurgen-Jm-Imports (see edit history)
rare racing hearts
http://jmimports.mine.nu:10100/yahoo/trans_parts.php?code=JmQxMDg5NTUyMTUmaHR0cDovL2Y0LmF1Y3Rpb25zLmMueWltZy5qcC9pbWczNzMuYXVjdGlvbnMueWFob28uY28uanAvdXNlcnMvNS81LzMvMy9tYXNhOTExcnNyLXRodW1iLTEyNzg1NDE5OTM2Mzk3MS5qcGc=
cheap ssr alloys
http://jmimports.mine.nu:10100/yahoo/trans_parts.php?code=Jmc4OTMwODgyNyZodHRwOi8vZjQuYXVjdGlvbnMuYy55aW1nLmpwL2ltZzIzMS5hdWN0aW9ucy55YWhvby5jby5qcC91c2Vycy81LzcvNC83L2NzZ3JpcC10aHVtYi0xMjY4NTU3OTM0MTQwMTcuanBn
i cant look for items for you as its time consuming i can spend hours on this yahoo and still not find things..( i will try to help as much as possible).
so if you find the link please send to me and i will price it up.
also its only ideal to use the container system if the items are heavy, bulky or large..
small items we can ship via ems.:)
I cant make heads or tails out of those webites, admittedly i was only browsing but still. You are clearly a clever (or very patient man) Jurgen
its very easy, most of it is search menus..
once you have located the parts or items on drop down menus just click search..
then it will give you the items found, then you click on them..
hope it helps.
£150 for all items unless you buy 5 items
Would that be the same for a set of rear lights for a different car?
Or would it be better just to get it airmailed? Only thing is dont speak or read japanese
i fancy some new wheels but it will take forever to look through this lot:search:
also what is the exchange rate like havn't got a clue how to work yen etc out:blink:
yum - http://jmimports.mine.nu:10100/yahoo/trans_parts.php?code=JmQxMDg5NTUyMTUmaHR0cDovL2Y0LmF1Y3Rpb25zLmMueWltZy5qcC9pbWczNzMuYXVjdGlvbnMueWFob28uY28uanAvdXNlcnMvNS81LzMvMy9tYXNhOTExcnNyLXRodW1iLTEyNzg1NDE5OTM2Mzk3MS5qcGc=
  • 3 weeks later...
