Andrew Dunk Shaw Posted December 16, 2002 Share Posted December 16, 2002 Im looking at the Blitz boost controllers and cant quite decide if the R spec with dual solenoid is worth the extra dosh over the S spec. It appears that there both the same other than the R spec has a dual solenoid, what advantage do this have over the S spec with the single solenoid. Have read the Blitz info but it doesn't really tell you that much. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 16, 2002 Share Posted December 16, 2002 I know the Dual Soleniod will hold 2.5 bar boost - not sure of the stats on the other. I have the SBC-ID VII which is the same controller as the Type R apart from the screen... If you are going single turbo at some point in the future then the Type R is gonna be the one to go for (judging by your Type R intercooler, maybe you are?). Gaz. Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted December 16, 2002 Author Share Posted December 16, 2002 Originally posted by gazwalker I know the Dual Soleniod will hold 2.5 bar boost - not sure of the stats on the other. I have the SBC-ID VII which is the same controller as the Type R apart from the screen... If you are going single turbo at some point in the future then the Type R is gonna be the one to go for (judging by your Type R intercooler, maybe you are?). Gaz. No Gaz the R spec intercooler was overkill on my part, i'd had a nice little earn and had a few ££££'s to part with so i tossed a coin and it landed on heads which was the R spec FMIC. Im not going single turbo as when my car gets somewhere over the 400 hp mark that'll be fine for me + my cars an auto so i'll be sticking after these mods as i dont want to be giving the g box a hard time. Once ive got my hp to 400+ my money will go on other bits such as front bumper and rear wing and maybe a mad paint job Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted December 16, 2002 Share Posted December 16, 2002 Originally posted by Andrew Dunk Shaw No Gaz the R spec intercooler was overkill on my part, i'd had a nice little earn and had a few ££££'s to part with so i tossed a coin and it landed on heads which was the R spec FMIC. Im not going single turbo as when my car gets somewhere over the 400 hp mark that'll be fine for me + my cars an auto so i'll be sticking after these mods as i dont want to be giving the g box a hard time. Fair enough then! Gaz. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted December 16, 2002 Share Posted December 16, 2002 I would go with the R-Spec, just in case. As Gaz says the dual solenoid one will work at higher boost levels. What is the price difference Andrew ? Quote Link to comment Share on other sites More sharing options...
Andrew Dunk Shaw Posted December 16, 2002 Author Share Posted December 16, 2002 Originally posted by Martin F I would go with the R-Spec, just in case. As Gaz says the dual solenoid one will work at higher boost levels. What is the price difference Andrew ? Theres not a great deal of money in it about £150 ish more for the R spec, its just that when ive got to my 400+ hp i'll be more than happy with the engine performance and my only mods will be cosmetic and brakes. Suppose i'll end up with the R spec but if the S spec is fine for what i want i'd rather put the extra ££'s toward the other goodies. Quote Link to comment Share on other sites More sharing options...
