ray007 Posted July 24, 2010 Share Posted July 24, 2010 Looking for an R154, Just wondering are there if any differences between one from a soarer and one from a Mkiii supra? thanks in advance for your time Link to comment Share on other sites More sharing options...
Attero Posted July 24, 2010 Share Posted July 24, 2010 What a coincidence... this just popped up. Worth a look (if you haven't already). http://www.mkivsupra.net/vbb/showthread.php?t=223871 Link to comment Share on other sites More sharing options...
HadeS Posted July 24, 2010 Share Posted July 24, 2010 There is one on ebay atm. I think they are the same but one from soarer is so rare. Link to comment Share on other sites More sharing options...
bignum Posted July 24, 2010 Share Posted July 24, 2010 The 154 from a soarer will fit straight into a mkiv, the mark 3 needs a shifter conversion. Pretty rare though soarer manual! Link to comment Share on other sites More sharing options...
ray007 Posted July 24, 2010 Author Share Posted July 24, 2010 There is one on ebay atm. I think they are the same but one from soarer is so rare. ive been keeping an eye on that thanks any way... is that one defo from a soarer? to fit on a 1jz engine am i right in saying i will need the prop, master and slave and the shifter extension? Link to comment Share on other sites More sharing options...
HadeS Posted July 24, 2010 Share Posted July 24, 2010 This one on ebay is from MKIII mate. Link to comment Share on other sites More sharing options...
Kirk Posted July 24, 2010 Share Posted July 24, 2010 The 154 from a soarer will fit straight into a mkiv, the mark 3 needs a shifter conversion. Pretty rare though soarer manual! Not entirely true mate, the later model soarers had the correct box the early models didnt have a remote shifter Link to comment Share on other sites More sharing options...
ray007 Posted July 24, 2010 Author Share Posted July 24, 2010 The 154 from a soarer will fit straight into a mkiv, the mark 3 needs a shifter conversion. Pretty rare though soarer manual! so which flywheel would i use? and could use the mkiv clutch? (i doubt it) and can i not use the pedals and master&slave from an mkiv w58 or v161? Link to comment Share on other sites More sharing options...
Swampy442 Posted July 24, 2010 Share Posted July 24, 2010 Mk4 flywheel, mk4 clutch Still no reply on the engine btw mate Link to comment Share on other sites More sharing options...
ray007 Posted July 24, 2010 Author Share Posted July 24, 2010 Mk4 flywheel, mk4 clutch Still no reply on the engine btw mate and is that the same if i was using the 1jz engine? could i still use the MK4 flywheel and clutch? Link to comment Share on other sites More sharing options...
Swampy442 Posted July 24, 2010 Share Posted July 24, 2010 AFAIK the flyis the same between both engines. Oops, looks like I just bought an R154 Oh well for 310 quid Ill just pump it on DriftWorks, double my cash lol Link to comment Share on other sites More sharing options...
ray007 Posted July 24, 2010 Author Share Posted July 24, 2010 AFAIK the flyis the same between both engines. Oops, looks like I just bought an R154 Oh well for 310 quid Ill just pump it on DriftWorks, double my cash lol Naughty naughty, just adding to your collection or something..lol... what are you using it for then? ive recently joined driftworks.....some prices are extortionate but at the same time there's some really stuff aswell. Link to comment Share on other sites More sharing options...
HadeS Posted July 24, 2010 Share Posted July 24, 2010 Swampy are you going to collect it or send it by curier? Link to comment Share on other sites More sharing options...
garethr Posted July 24, 2010 Share Posted July 24, 2010 Mk4 flywheel, mk4 clutch ...Confusion with the W58, Craig? You have too many gearboxes! If you're fitting the R154 to any JZ you need a 1JZ/R154 flywheel and bellhousing, and a 1JZ or 7M R154 clutch. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 24, 2010 Share Posted July 24, 2010 Gareth, as the JZ god can always rely on you for important info I do have too many gearboxes, in my garage I have a W58, an HSK built auto and soon to have an R154 lol Link to comment Share on other sites More sharing options...
ray007 Posted July 24, 2010 Author Share Posted July 24, 2010 Gareth, as the JZ god can always rely on you for important info I do have too many gearboxes, in my garage I have a W58, an HSK built auto and soon to have an R154 lol lol... i think im just as bad as you.. i have v161 conversion and a w58 conversion just sitting there and now im looking for an R154 Link to comment Share on other sites More sharing options...
Swampy442 Posted July 25, 2010 Share Posted July 25, 2010 Trade you the 6 speed or the 5 speed Link to comment Share on other sites More sharing options...
HadeS Posted July 25, 2010 Share Posted July 25, 2010 If you're fitting the R154 to any JZ you need [...] a 1JZ or 7M R154 clutch. Is this true? Dont like it then. Link to comment Share on other sites More sharing options...
ray007 Posted July 30, 2010 Author Share Posted July 30, 2010 hi all if i get the R154 from a soarer, would i need the PROP and Starter to fit in an n/a with a 1jz lump? Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 30, 2010 Share Posted July 30, 2010 we need some definative answers here. can someone knowlageable that know for sure (not thinking or guessing) fill in the following mk3 r154 box to fit 2jz will need a ________ bell housing , A ________ clutch and will mate to a _______ prop . The shifter will/will not need extending a sorer r154 box to fit 2jz will need a ________ bell housing , A ________ clutch and will mate to a _______ prop . The shifter will/will not need extending the shifter extension needed can be baught from_______ or taken from a _________ thank you Link to comment Share on other sites More sharing options...
Kirk Posted July 30, 2010 Share Posted July 30, 2010 As ive said time and time again there are many types of r154, 4 last time i checked but theres only one you want and thats out of the later soarer which has remote shifter but good luck finding one of those cheap or at all... Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 30, 2010 Share Posted July 30, 2010 As ive said time and time again there are many types of r154, 4 last time i checked but theres only one you want and thats out of the later soarer which has remote shifter but good luck finding one of those cheap or at all... but there must be other ways of making the mk3 or earlyer soarer box fit ? Link to comment Share on other sites More sharing options...
Kirk Posted July 30, 2010 Share Posted July 30, 2010 Yeah a shifter extention which isnt something i would do myself but each to there own. Link to comment Share on other sites More sharing options...
ray007 Posted July 30, 2010 Author Share Posted July 30, 2010 Trade you the 6 speed or the 5 speed what my w58 box for your R154? Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 30, 2010 Share Posted July 30, 2010 (edited) Yeah a shifter extention which isnt something i would do myself but each to there own. is there a way of madofying the w58 exstension to fit the 154 from the mk3. i need to find these things out as my latest w58 is starting to develope the "death whine" . for instance i have a full w58 in bits so could i use the 58 bell housing and shifter to make a mk3 box fit. i wnat a 154 as the raios are pretty similar to the w58 and would work well with the na diff, and i can buy a mk3 turbo (rust bucket with knackerd engine ) for £300 Edited July 30, 2010 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
