Jellybean Posted July 24, 2010 Share Posted July 24, 2010 How can I torque the an fittings to 30nm, I just have basic spanners thanks Quote Link to comment Share on other sites More sharing options...
heckler Posted July 24, 2010 Share Posted July 24, 2010 you can't - you need a torque wrench... Quote Link to comment Share on other sites More sharing options...
chrispot Posted July 24, 2010 Share Posted July 24, 2010 How can I torque the an fittings to 30nm, I just have basic spanners thanks have you got a spring balance or baggage scales if so you could use one to set the torque, example 10lbs ft is, a torque of 10 lbs on a radius of 1 foot, or 20lbs at 6 inches, so you could measure spanner/ bar lenth and work out what torque is needed on that lenth, hope that makes sense, regards chris Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 24, 2010 Author Share Posted July 24, 2010 Thanks , just says not to exceed 30nm , so just tight but dont go nuts I presume Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2010 Author Share Posted July 26, 2010 you can't - you need a torque wrench... Stupid Q, but the An Fitting wont allow me to use a socket , I can only use an open Spanner What tool would you use, tried looking for a Torque Spanner Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted July 26, 2010 Share Posted July 26, 2010 Thanks , just says not to exceed 30nm , so just tight but dont go nuts I presume Yeah, 30nm really isn't that tight. It's the lowest setting my torque wrench goes to anyway. Quote Link to comment Share on other sites More sharing options...
MartinBattye Posted July 26, 2010 Share Posted July 26, 2010 you would use a crows foot spanner with 3/8 attachement... tbh that warning is there since the fittings are delicate.. just dont go mental with tight.. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2010 Author Share Posted July 26, 2010 you would use a crows foot spanner with 3/8 attachement... tbh that warning is there since the fittings are delicate.. just dont go mental with tight.. Cool Thanks for all the help Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 26, 2010 Share Posted July 26, 2010 resistance and 1/4 of a turn allways dose me Quote Link to comment Share on other sites More sharing options...
