jevansio Posted July 23, 2010 Share Posted July 23, 2010 Is there such a thing as flexible pipe that can be used as intercooler pipework? Coming off the turbo going to the FMIC there ain;t much room due to the steering rack/water neck from block. Is there like a felxible sameco hose type thing that I can use in that area just to make fitting it easier? (3" diameter) Link to comment Share on other sites More sharing options...
JamieP Posted July 23, 2010 Share Posted July 23, 2010 (edited) 76mm might be tricky to find, viper do some flexi stuff but it only goes to 63mm, might be worth an email to them though. http://www.viperperformance.co.uk/ These joiners have a small amount of flex in them. http://www.viperperformance.co.uk/productsearch.php?xscId=2975&mat=104&filter=76.20%20mm Edited July 23, 2010 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
jevansio Posted July 23, 2010 Author Share Posted July 23, 2010 Cheers bud, will contact them, Link to comment Share on other sites More sharing options...
Swampy442 Posted July 23, 2010 Share Posted July 23, 2010 By flexi do you mean metal with flexi bits like an exhaust or a sillcone section? Roose Motorsport in Lincoln can make anything you want, I use them all the time, most recently for nomex wrapped hight temp coolant lines. Link to comment Share on other sites More sharing options...
jevansio Posted July 23, 2010 Author Share Posted July 23, 2010 I mean like a silicone hose that I can bend a bit just to get through a tricky area without having loads of joins, cheers will look into them too Link to comment Share on other sites More sharing options...
Swampy442 Posted July 23, 2010 Share Posted July 23, 2010 Yeah man, Roose Motorsport is for you. Top guys and can make anything you desire in any size and colour combo in 24 hrs. If you need it posting give me a shout, Ill collect and post it. http://www.roosemotorsport.co.uk/ Link to comment Share on other sites More sharing options...
jevansio Posted July 24, 2010 Author Share Posted July 24, 2010 Many thanks Swampy, I will be onto them Monday morning Link to comment Share on other sites More sharing options...
mikeyb10supra Posted July 24, 2010 Share Posted July 24, 2010 Would the stock piping not do the job? Link to comment Share on other sites More sharing options...
jevansio Posted July 24, 2010 Author Share Posted July 24, 2010 Stock as in OEM or stock as in original 4row piping? OEM is too small (I need 3"), and 4Row is very difficult (but not impossible) to manoeuvre in the tight space. I would like something a little more "flexible" than solid 3" pipe Link to comment Share on other sites More sharing options...
