Flexible intercooler pipe
jevansio
Is there such a thing as flexible pipe that can be used as intercooler pipework?
Coming off the turbo going to the FMIC there ain;t much room due to the steering rack/water neck from block.
Is there like a felxible sameco hose type thing that I can use in that area just to make fitting it easier? (3" diameter)
76mm might be tricky to find, viper do some flexi stuff but it only goes to 63mm, might be worth an email to them though.
http://www.viperperformance.co.uk/
These joiners have a small amount of flex in them.
http://www.viperperformance.co.uk/productsearch.php?xscId=2975&mat=104&filter=76.20%20mm
Edited by JamieP (see edit history)
Stock as in OEM or stock as in original 4row piping? OEM is too small (I need 3"), and 4Row is very difficult (but not impossible) to manoeuvre in the tight space. I would like something a little more "flexible" than solid 3" pipe
