mwilkinson Posted July 23, 2010 Share Posted July 23, 2010 (edited) Can somebody with the epc find the part numbers for the following items please. All for jspec tt manual Foot rest - believe it's 58194-24010 Handbrake - believe it's 46201-14260 c3 Throttle cable Oil pump Water pump Real crank oil seal Rear gearbox oil seal Engine mounts Gearbox mounts Pipe from turbo to airbox fan shroud Thanks. Edited July 23, 2010 by mwilkinson (see edit history) Link to comment Share on other sites More sharing options...
Gambit Posted July 23, 2010 Share Posted July 23, 2010 (edited) Cable Assy, Throttle 35520-24060 Pump Assy, Oil 15100 46051 I could go on but thinking about it, you're better off going into Mr. T with your chassie number and getting numbers off him. your chassie number will bring up the exact parts and rule out mistakes. Saves mixing TT to N/A, Auto to Manual..... Edited July 23, 2010 by Gambit (see edit history) Link to comment Share on other sites More sharing options...
mwilkinson Posted July 23, 2010 Author Share Posted July 23, 2010 I see your point. I use to use toyodiy before they got rid of the image side. Can you be kind enough to tell me the fan shroud part number please as mine was destroyed when an intercooler pipe broke loose at 1.2 bar on a spirited drive. Pretty please Cable Assy, Throttle 35520-24060 Pump Assy, Oil 15100 46051 I could go on but thinking about it, you're better off going into Mr. T with your chassie number and getting numbers off him. your chassie number will bring up the exact parts and rule out mistakes. Saves mixing TT to N/A, Auto to Manual..... Link to comment Share on other sites More sharing options...
Inferno Posted July 24, 2010 Share Posted July 24, 2010 PM sent! Reference for others... shroud component part numbers: 16711-46160 Shroud, Main 16711-46170 Aux Fan Motor Bracket 16702-46010 Shroud, Main Lwr 16715-46010 Bracket, Shroud Link to comment Share on other sites More sharing options...
The Raven Posted July 24, 2010 Share Posted July 24, 2010 What are you doing with that little lot matt? Link to comment Share on other sites More sharing options...
