mcockcroft Posted July 23, 2010 Share Posted July 23, 2010 Hi i have just bought a 1994 Supra UK version twin turbo, and has a pretty bad oil leak. Hopefully the picture will attach ok, but it is coming from a sensor located between the air con unit and the block. It can be seen if stood near the NSF wheel Hope someone can identify it, i think it might possibly be an oil pressure sensor but i cant be sure any help is appreciated cheers martin Quote Link to comment Share on other sites More sharing options...
keron Posted July 23, 2010 Share Posted July 23, 2010 oil pressure switch...common fault... Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 23, 2010 Share Posted July 23, 2010 and easy fix............. NB there is an uprated part for this (should be the only one they give you) which is a slightly different size than the one that you'll take off (presuming that its original) About £10-15 from toyota Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 23, 2010 Share Posted July 23, 2010 http://www.mkivsupra.net/vbb/showthread.php?t=18480&highlight=oil+pressure+switch Some good info here Quote Link to comment Share on other sites More sharing options...
mcockcroft Posted July 23, 2010 Author Share Posted July 23, 2010 superb fellas, great advice, will get one ordered and get stuck in, thanks for the link scooter very helpful Quote Link to comment Share on other sites More sharing options...
