SupraP-Z Posted July 22, 2010 Share Posted July 22, 2010 Hey guys, have a question about what oil i should be using in a 1.4 zetec engined ford fiesta? In the manual it states i should be using SAE 5W-30, but it says if i dont have that i can also use 10w40. Went down to Eurocarparts and they just gave me 10w40 because the engine has over 80,000 miles on it (bought it already). Got home and a look on the net, and it wasnt really clear what i should be using. I did find a bunch of stuff saying something about valves sticking if higher viscosity oil is used, and zetec engines are only really are compatible with the 5w-30? Im confused...what do i use? :S Thanks for any help Link to comment Share on other sites More sharing options...
Attero Posted July 22, 2010 Share Posted July 22, 2010 Try looking at Halfords table of oils to use for your car. Don't have to buy anything from them. Just check the shelf-booklets they have around their oil shelves. Link to comment Share on other sites More sharing options...
nigelboyne Posted July 22, 2010 Share Posted July 22, 2010 10w 40 semi will be fine Link to comment Share on other sites More sharing options...
SupraP-Z Posted July 22, 2010 Author Share Posted July 22, 2010 Cheers guys, yeah ive got 10w40 semi...just worried that the car wont start up on cold! Link to comment Share on other sites More sharing options...
j_jza80 Posted July 22, 2010 Share Posted July 22, 2010 it may vary my marque. Link to comment Share on other sites More sharing options...
Brett 1 Posted July 22, 2010 Share Posted July 22, 2010 When i had my fiesta i used 5w30 and it was fine Link to comment Share on other sites More sharing options...
Lee P Posted July 22, 2010 Share Posted July 22, 2010 I would put 5w30 in it. Link to comment Share on other sites More sharing options...
movistar Posted July 23, 2010 Share Posted July 23, 2010 5w30 would be what you would get in a ford service, saying that 10w40 wont hurt it. Although if this is oil is used and your engine internals are not actually that worn and at 80k if regularly serviced I would say they probably are not it may seem to have less performance. Note:The alternative viscosity oil's in the hand book are usually a guide for topping up and external ambient temp differences. E.G a hot or cold country. Link to comment Share on other sites More sharing options...
stevie_b Posted July 23, 2010 Share Posted July 23, 2010 If it's a Sigma-engined Fiesta I would only put 5w-30 in it. Consensus in the Fiesta Owners Club forum is that these engines need (not just "want") this grade of oil. I would only put 10w-40 in it if the engine's already on borrowed time. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 23, 2010 Share Posted July 23, 2010 I just put any cheap stuff in mine, at the rate it uses the stuff, and its not rattling any more than it used to.... Link to comment Share on other sites More sharing options...
stevie_b Posted July 23, 2010 Share Posted July 23, 2010 I just put any cheap stuff in mine, at the rate it uses the stuff, and its not rattling any more than it used to.... Pre-detonation? If so my "borrowed time" clause may apply to your engine. Link to comment Share on other sites More sharing options...
Guest ugp Posted July 23, 2010 Share Posted July 23, 2010 It is indeed on borrowed time, your clause definately applies to it! Do you mean detonation or pre ignition? Link to comment Share on other sites More sharing options...
stevie_b Posted July 23, 2010 Share Posted July 23, 2010 Hmm, not sure! It seems "pre-detonation" is a mistaken term as you correctly pointed out. It's something I read here: http://www.ukfiestanetwork.com/index.php?showtopic=166190 Link to comment Share on other sites More sharing options...
Guest ugp Posted July 23, 2010 Share Posted July 23, 2010 (edited) Hmm, not sure! It seems "pre-detonation" is a mistaken term as you correctly pointed out. It's something I read here: http://www.ukfiestanetwork.com/index.php?showtopic=166190 Indeed it is. The link below explains both terms better than I could: http://www.streetrodstuff.com/Articles/Engine/Detonation/Page_2.php Edited July 23, 2010 by ugp Fat Fingers - Spelling (see edit history) Link to comment Share on other sites More sharing options...
