salvatore Posted June 6, 2005 Share Posted June 6, 2005 Well, today i deceided to fit my recently arrived earthing kit (courtesy of Miami GT). Seeing as i had to use a decent earth at the offside front of the bonnet, i deceided to use the bolt fixing my catch tank to the inner 'lip' of the bumper top. Having removed the catch tank, thought it would be a good idea to empty it out. Took off the hoses, removed the small blocking grub screw (it's a greddy item BTW), and went to drain it out. What came out can only be described as runny brown shit! In fact, not unsimilar to that you get in baby's nappies (yum!) plus a bit of oily water. Now, apart from being a bit amused by the 'discharge' , i am somewhat worried. Is this what is meant ot come out, or is my soop suffering a monumental bout of the shits! I guess it's the action of the oil emulsifying with the water and air mix to produce a 'mousse', but has anyone else experienced this (rather amusing) effect? Quote Link to comment Share on other sites More sharing options...
uk-rich Posted June 6, 2005 Share Posted June 6, 2005 not sure on this one, however it would be really helpful if you pm me how to fit one, i know there is only two pipes to connect, but where do you connect them to ! any help would be great Quote Link to comment Share on other sites More sharing options...
TRD3000GT Posted June 6, 2005 Share Posted June 6, 2005 thats what is supposed to come out its just bad oil Quote Link to comment Share on other sites More sharing options...
Pete Posted June 6, 2005 Share Posted June 6, 2005 Watery mix due to condensation. Quote Link to comment Share on other sites More sharing options...
JohnA Posted June 6, 2005 Share Posted June 6, 2005 As said, it's normal mate Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted June 6, 2005 Share Posted June 6, 2005 getting your car checked over? Wise move - 2 weeks Quote Link to comment Share on other sites More sharing options...
Guest a71ak Posted June 6, 2005 Share Posted June 6, 2005 Here's a drawing I made while ago in how you get your catch tank connected ... Just per in mind that you can use only the turbo side source ... and leave the intake side as stock .... OR ... you can connect both side through a T .... Both will have the same effect since they are connected internally. http://sahari.jeeran.com/Oil%20Catch%20Tank2.JPG GOOD LUCK!! Quote Link to comment Share on other sites More sharing options...
uk-rich Posted June 6, 2005 Share Posted June 6, 2005 brill, thaks very much Quote Link to comment Share on other sites More sharing options...
salvatore Posted June 6, 2005 Author Share Posted June 6, 2005 Cheers for the input guys - bit more reassured now! Bobbeh - getting new brake pads fitted and oil change soon, plus new FMIC and oil cooler from Paul E - should be in fine fettle by then m8! Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted June 7, 2005 Share Posted June 7, 2005 I dunno if this is a dumb ass question or not.....but do standard supra's have some sort of catch tank then??? if not where does all this brown oily/water crap go?? Quote Link to comment Share on other sites More sharing options...
slick Posted June 7, 2005 Share Posted June 7, 2005 I dunno if this is a dumb ass question or not.....but do standard supra's have some sort of catch tank then??? if not where does all this brown oily/water crap go?? In the intercooler and any that makes it through gets burnt up I'd imagine in the mix. Quote Link to comment Share on other sites More sharing options...
Digsy Posted June 7, 2005 Share Posted June 7, 2005 I dunno if this is a dumb ass question or not.....but do standard supra's have some sort of catch tank then??? if not where does all this brown oily/water crap go?? All modern cars have a closed breather system. Crankcase gases and carried over oil get recycled into the air intake. On part throttle, it goes into the system after the throttle body. At WOT it goes in before the throttle body but after the air filter. Quote Link to comment Share on other sites More sharing options...
