SupraTTBPU Posted July 20, 2010 Share Posted July 20, 2010 Hello all together, I'm going single, and did a compression test: Here are the bad results: http://img690.imageshack.us/img690/7772/p7200036.jpg Is my engine blown ? What to do next, any advices to do to sort something out ? Or to "analyze" the complete engine to look what happened ? cheers from Germany Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 20, 2010 Share Posted July 20, 2010 it seems you are missing a cylinder? but i wouldnt single that engine Quote Link to comment Share on other sites More sharing options...
bignum Posted July 20, 2010 Share Posted July 20, 2010 Does the motor run ok, i would have thought you`d have a missfire with no compression on 6. And some smoke. Quote Link to comment Share on other sites More sharing options...
absz Posted July 20, 2010 Share Posted July 20, 2010 Its either bad compression or the battery was fading during the test ? ALSO as mentioned you are missing a cylinder, just buy a cheap compression gauge from halfords and do your own test before going any further:) Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 20, 2010 Share Posted July 20, 2010 Leakdown test is the way to go ! Quote Link to comment Share on other sites More sharing options...
SupraTTBPU Posted July 20, 2010 Author Share Posted July 20, 2010 Thx to all replies I will check soon Quote Link to comment Share on other sites More sharing options...
David Reid Posted July 21, 2010 Share Posted July 21, 2010 Did you do the compression check correctly, i.e WOT and fuel pump or injectors disconnected? Have you missed the result from 6? 5 also looks poor Quote Link to comment Share on other sites More sharing options...
dude Posted July 22, 2010 Share Posted July 22, 2010 As already said you need to get a leakdown test done but if No 6 has no compression then you do have problems that will involve a strip down. Quote Link to comment Share on other sites More sharing options...
