help!! starter motor gone!
simon H
1) NEW one = Toyotas ?
2) Pattern/Refurbished one = unlikely ?
3) Get your one stripped and 'parts' fixed...... MUST be a
place that repairs Alternators/Starters close to you ! We're doing
it all the time - some of the REFURB'ED ones cost a fortune - repairs
normally between £30 and £80 - they strip and just fix what's gone
AS LONG AS it's not 'broken', casing etc....then it's new/refurb anyway
[ps. we have several in Dagenham, but always use a Lucas agent...
~same prices, but, has parts more often, and, will be there LATER !]
>> should find in Yellow Pages or, ask local garages ??
FatS.
Originally posted by simon H
HI
Just had the RAC out and my starter motor has gone, does anyone know where I could get one and get it fitted around the Bedfordshire area? The RAC are going to tow it to a garage??
Thanks in advance
Simon
Unless it's totally *uggered i can rebuild it for you, but am in Shropshire, if you get stuck you could courier it over.
If you are not sorted yet, try Trevor Pridham at Toyota Celica Breakers. They got me a power steering pump at a fifth of the price from Toyota and shipped it next day for a tenner.
Number is 01579 383879 or After Hours 01579 362762
Based in Cornwall.
Hope this helps
Same thing has just happened to me - but how do I know if it is the contacts, solenoid or the motor itself? (Just makes one click when I turn the key). Its a real bitch at the moment as the car is now trapped nose first in the garage. Toyota quoted £280 for a refurb and £320 for replacement?
Unless I can somehow get it started (trusty AA man) I may have to get it towed to the Toyota garage. (Embarassing)
Any ideas or shall I just have done with it and lay the car up for the winter? However I used to turn the motor over occasionally just to keep things lubed - can't even do that without a working starter motor.
I only use the car when weather is good and was going to give it a run tonight as no rain was forecast for once. Typical huh!
Any help greatly appreciated.
Rich
