geordie82 Posted July 19, 2010 Share Posted July 19, 2010 finally got around to fitting the glass headlights in the beasty n/a looks amazing fitted the hids i got from group buy, didnt quite fit so had to give them a file down, fitted the ballests after alot of shouting swearing and bleeding everything was in perfect. or so i thought everything is working other than dipped beam ie new hids looked at the wiring diagram and all is as it should be well 2nd time around, checked all the fuses under the bonnet, since im guessing i blew it having it wrong the first time, none are blown, is there another fusebox and if so help i cant find the damn thing Quote Link to comment Share on other sites More sharing options...
Nic Posted July 20, 2010 Share Posted July 20, 2010 Other fuse box is in drivers footwell under the dash. Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted July 20, 2010 Share Posted July 20, 2010 finally got around to fitting the glass headlights in the beasty n/a looks amazing fitted the hids i got from group buy, didnt quite fit so had to give them a file down, fitted the ballests after alot of shouting swearing and bleeding everything was in perfect. or so i thought everything is working other than dipped beam ie new hids looked at the wiring diagram and all is as it should be well 2nd time around, checked all the fuses under the bonnet, since im guessing i blew it having it wrong the first time, none are blown, is there another fusebox and if so help i cant find the damn thing sometimes hid's sourced from asia are wired the wrong way round with black being rail and red being ground for some reason, if your still having problems try swapping them around and see if thats the problem. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 20, 2010 Share Posted July 20, 2010 Quote Link to comment Share on other sites More sharing options...
geordie82 Posted July 20, 2010 Author Share Posted July 20, 2010 thanks guys help is much apreciated Quote Link to comment Share on other sites More sharing options...
