marbleapple Posted July 19, 2010 Share Posted July 19, 2010 Evening all, When I download a file, it downloads as it should (and space is taken on the hard disk) but the file does not appear where it should (and I cannot find it by searching). I am fairly certain that Windows is hiding it for some reason. I have searched the net and the only 2 useful suggestions to resolve the problem I have found are 1. Turn off Account Control (which is already turned off) 2. AVG is stopping it/AVG isn't being allowed to run (I don't have AVG although I did have it at some point and "scan with AVG still appears when I right click despite deleting AVG and alnot being able to find any AVG files) Does anyone have any solutions and on a second note, does anyone know how to rid me of the AVG elements forever? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 19, 2010 Share Posted July 19, 2010 Which version of Windows are you running? What types of files have you tried downloading (e.g. .doc, .pdf)? If you've downloaded e.g. a pdf, can you see other pdfs on your hard drive? What browser are you using? In Firefox you can choose where files get downloaded to, or you can make the browser ask you for a location every time. I can't remember if IE is similar, it's been so long since I've used it. It does sound like your AVG (or what's left of it) could be placing the files in some sort of quarantine/holding area. I haven't heard of AV software doing this before (apart from for virus threats) but it's possible a broken copy could be doing this. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 19, 2010 Share Posted July 19, 2010 Think the main thing is what type of Internet browser are you using? Some file them away into a neat "download" folder which you should be able to access. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 19, 2010 Author Share Posted July 19, 2010 Hi. It is IE8. Firefox doesn't work either. They are downloading but the files are not appearing. Its an MP3 I am trying to download and it doesn't seem to be a problem when I download pictures. Some file them away into a neat "download" folder which you should be able to access. My downloads doesn't have the downloads either. The problem only started a few weeks ago, it used to save where I asked it to. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 19, 2010 Share Posted July 19, 2010 Hi. It is IE8. Firefox doesn't work either. They are downloading but the files are not appearing. Its an MP3 I am trying to download and it doesn't seem to be a problem when I download pictures. My downloads doesn't have the downloads either. The problem only started a few weeks ago, it used to save where I asked it to. Hey, And what type of OS are you using (XP/Vista/Windows7?) Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 19, 2010 Author Share Posted July 19, 2010 Hey, And what type of OS are you using (XP/Vista/Windows7?) Apologies. Vista Quote Link to comment Share on other sites More sharing options...
SupraDan24 Posted July 19, 2010 Share Posted July 19, 2010 What program are you using to download the files ie Azures, uTorrent etc?? Try creating a new folder, going into the settings and changing the destination to the new folder. Dan Quote Link to comment Share on other sites More sharing options...
stevie_b Posted July 19, 2010 Share Posted July 19, 2010 If it's only MP3s that are a problem, I'd suspect some software may be blocking them. Also, are you sure that Windows Explorer isn't set to hide MP3s in the download folder? Seems unlikely, but worth checking. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 19, 2010 Author Share Posted July 19, 2010 I am not using anything to download. I click on the link and I can 'open' or 'save as'. Either way doesn't work where ever I try to down load. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 19, 2010 Author Share Posted July 19, 2010 If it's only MP3s that are a problem, I'd suspect some software may be blocking them. Also, are you sure that Windows Explorer isn't set to hide MP3s in the download folder? Seems unlikely, but worth checking. Downloading programs also seems to be a problem. Any downloading from a link. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 19, 2010 Share Posted July 19, 2010 If that is the case then it does sound like your Anti virus S/W could most likely be blocking it. When you click save, can you see it downloading? So there is a progress bar? This would rule out any pop up blocker stopping the MP3 files from downloading. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 19, 2010 Author Share Posted July 19, 2010 If that is the case then it does sound like your Anti virus S/W could most likely be blocking it. When you click save, can you see it downloading? So there is a progress bar? This would rule out any pop up blocker stopping the MP3 files from downloading. Yes I can. I don't have a virus scanner though. Quote Link to comment Share on other sites More sharing options...
Abz Posted July 19, 2010 Share Posted July 19, 2010 Yes I can. I don't have a virus scanner though. Sorry you did mention it is being download as it is taking space up on the hard drive. Could you a search on the hard drive with the follow: *.mp3 Quote Link to comment Share on other sites More sharing options...
Attero Posted July 19, 2010 Share Posted July 19, 2010 I take it you have downloaded files before and you know where they are placed? If you haven't, check the location of your download folder via your tools. If you've installed new applications that set your default download folder, this could also be your problem. I've had the same thing happen before and wandered where the hell my files went! As for Windows 7, there is actually a downloads folder for all your downloads built into the OS. Check your libraries! Quote Link to comment Share on other sites More sharing options...
creative Posted July 20, 2010 Share Posted July 20, 2010 sounds like what I had..... in firefox type.... about:config into the addy bar scroll down and look for browser.download.manager.scanWhenDone change this to false. whats happening is windows/antivirus is scanning the downloaded file and doesnt recognize it... so deletes it automatically. took me ages to find this out! Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 21, 2010 Author Share Posted July 21, 2010 Could you a search on the hard drive with the follow: *.mp3 HI Mate, It is not just MP3's. It seems to be programmes too. Sorry for the delay in replying guys sounds like what I had..... in firefox type.... about:config into the addy bar scroll down and look for browser.download.manager.scanWhenDone change this to false. whats happening is windows/antivirus is scanning the downloaded file and doesnt recognize it... so deletes it automatically. took me ages to find this out! I use IE8 not firefox. I never liked how Firefox looked TBH. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted July 21, 2010 Author Share Posted July 21, 2010 Edit: Now found what the problem is: PC Tools Spyware Doctor. Just disabled it and now it works Thanks all that tried to help. Appreciated. Quote Link to comment Share on other sites More sharing options...
