Guest manni Posted July 19, 2010 Share Posted July 19, 2010 hi guys, has anyone of you that tein super racing coilovers?? How it is to drive?? thanks Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 19, 2010 Share Posted July 19, 2010 What will you be using the car? For the money they charge you can get some much better dampers. Quote Link to comment Share on other sites More sharing options...
Guest manni Posted July 19, 2010 Share Posted July 19, 2010 Car used only on the road and track. I have 19" wheels with 10" 235/35 front and 12,5" 305/30 rear. I would like the EDFC use. I have the Tein Flex in the moment, that is terrible. It´s too soft. In the curves, at potholes. And the coilover squeaking by the compress. terrible What´s are better coilovers?? Tein Mono Flex ?? Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted July 19, 2010 Share Posted July 19, 2010 Sorry to high jack a little. Which suspension would you recommend Paul? Use is mostly Street but also a lot of Laps on the Nurburgring and maybe other Tracks. Also i would like adjustable dampers and height adjustment Sorry again and thanks for advice Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 19, 2010 Share Posted July 19, 2010 Take a look on here http://whifbitzperformancetuning.co.uk/toyota-supra-suspension-coil-overs-dampers-c-42_47_838_840.html I would highly recommend the Nitron dampers, thats what we use on our Time Attack Supra's and they work very very well. Quote Link to comment Share on other sites More sharing options...
Guest manni Posted July 19, 2010 Share Posted July 19, 2010 What for Nitron dampers would you recommend me Paul ?? Nitronsup2 or Nitronsup3 ?? What for Nitron dampers used you at the Time Attack Supra's ?? Nitron or Eibach springs ?? Spring Rate (kg/mm Front, kg/mm Rear) thanks Jürgen Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted July 20, 2010 Share Posted July 20, 2010 What for Nitron dampers would you recommend me Paul ?? Nitronsup2 or Nitronsup3 ?? What for Nitron dampers used you at the Time Attack Supra's ?? Nitron or Eibach springs ?? Spring Rate (kg/mm Front, kg/mm Rear) thanks Jürgen We use Nitron 3 way dampers with Eibach springs. Overkill for a road car though, the 1 way dampers will be fine. Depends on how serious you are on the track, having more adjustment can confuse you more with the setup. Quote Link to comment Share on other sites More sharing options...
