Problem cracking off a nut...
Ark
Chaps,
I'm trying to do some work on the wifes Subaru and have a little problem - Much like our beloved drop-links, the nut I need to crack off just spins the stud...the stud has a hex socket intended to restrain it, but how the heck does one put a hex socket wrench and a regular socket over the top? I can't go in from the side with a regular wrench, because the nut is recessed...
I did find something interesting that might help:
Special tube socket
Unfortunately this is the wrong size, and I can't find a 19mm version. Plus I bet I'll snapp any allen key I use to restrain the stud!!
So, has anyone got any bright ideas? 'Coz that'd be awesome.
I believe that the tube socket you pointed out are als known as injector removal sockets. Hope that helps you to find one with the size you need. You would be better off using an allen key in a rachet, theyre alot stronger that a standard allen key
Edited by nasoup (see edit history)
Thanks chaps - there's a tool for everything, isn't there!
That goose neck thing looks about right. Do they have any other names though? None of the usual web-stores seem to know...Quick trip to Halfords is probably in order!
Where abouts are you, I may know a man ;)
I'm on the north side of Winchester mate, any help gratefully received. Mind you, the whole thing might become academic - Jo is shopping for fancy top mounts now, so we won't have to re-use any parts.
More research suggests they're also called offset spanners - time to get more toys...I mean tools. ;)
  • 2 weeks later...
For the benefit of anyone who might be interested, I bought these:
Draper deep offset ring spanners
They didn't do the job because it was torqued too tight :(
So I bought one of these:
Clarke electric impact wrench
BZZZZ! Job done :)
Tell you what I want to add to my toolkit is a decent cordless variety of this impact gun. Mate of mine that's a mechanic has one and its £300 worth of awesomeness.
Yeah I saw there was a cordless version. Also a few other brands that run off the car battery, but I always find that the battery versions are flat just when I need them. Can't beat 240 volts of delicious alternating current! :)
