Dyer864 Posted July 19, 2010 Share Posted July 19, 2010 Hi All ! Bought some bottom boot/tailgate rubbers off ebay last week, as mine were perished and thought this could contribute to the squeak i had in the back, thanks to Sauron saying that there's a set on ebay with allen key bolts to attach to rear wing as the phillips heads are a f***er to get out !! And guess wot , they are a F***er to get out, couldn't budge them , Wd40'd them over night ( slight movement ) a hacksawed very cearefully a groove thro the head of the screw to get a flat head screwdriver in as i rounded the phillips head very easily , and guess wot ! YES i turned it and the head come off the screw:( Now i'm f***ed , no boot rubbers and a broken screw with no head ! Any ideas , looks like drilling it out, but cos of the boot rubber is higher it's awkward to get at Quote Link to comment Share on other sites More sharing options...
Ian W Posted July 19, 2010 Share Posted July 19, 2010 Should have used a bit of heat mate, seems to be the best way of getting the buggers out. Quote Link to comment Share on other sites More sharing options...
Spike3.0 Posted July 19, 2010 Share Posted July 19, 2010 Drill them out... Quote Link to comment Share on other sites More sharing options...
magictorch Posted July 19, 2010 Share Posted July 19, 2010 Heat them up a bit.....break the glue seal;) Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 19, 2010 Share Posted July 19, 2010 (edited) i know its to late but there are a few threads on how to get them out as they are glued in and heat is needed to break the bond. cut off all the rubber this leaves an oval plate , get a heat source of some kind be carefull with the bodywork , i used a small blow torch with a point atatchment so got the heat in on top of the screw two minutes and they were out Edited July 19, 2010 by peter richards (see edit history) Quote Link to comment Share on other sites More sharing options...
peter richards Posted July 19, 2010 Share Posted July 19, 2010 when the head broke off is there anything sticking out ? maybe able to get a small mole grip on whats there but still needs heat first Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 19, 2010 Author Share Posted July 19, 2010 Cheers guys !! looks like its too late on the head i broke ! Quote Link to comment Share on other sites More sharing options...
nevins Posted July 19, 2010 Share Posted July 19, 2010 Easiest way is to get a pair of maul grips on the remainder r the screw mate. Quote Link to comment Share on other sites More sharing options...
Terminator Posted July 19, 2010 Share Posted July 19, 2010 (edited) Toyota thread lock is awesome;) I had a similar problem when I tried to get mine out, I cut the rubber away, and got a gas soldering iron with a large tip on the oval, easy after that. Edited July 19, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
supra_bus. Posted July 19, 2010 Share Posted July 19, 2010 i bought these for mine also and the old ones were stuck on like poo to a blanket,in the end drilled them out and fitted with self-tappers not ideal i know but job done and no more rattle from tailgate!!! :cool: Quote Link to comment Share on other sites More sharing options...
evinX Posted July 19, 2010 Share Posted July 19, 2010 Put a solder iron on the head, to heat it up and and prise it out, they are siliconed in:) heat will soften the silicone Quote Link to comment Share on other sites More sharing options...
AlexJames Posted July 19, 2010 Share Posted July 19, 2010 Drill them out... Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted July 19, 2010 Share Posted July 19, 2010 Weird hearing these tales, the guy who did mine didnt have any issues at all, I guess he was just lucky Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 21, 2010 Author Share Posted July 21, 2010 (edited) Well after the advice i got on here, i got the soldering iron out whilst dodging the s***e weather we're aving and heated the screws up , whilst getting the oval plate out of the way first as it was a pain to get the maul grips on , and after a few attempts BINGO !! got them to undo, and the one screw with half a head on , came out easy enough as there was enough of it left to get the maulers on . and fitted the new ones in 5mins , alot easier with the allen type screw to put on Thanks guys for the info ! (didn't think there would be a search on these on how to get out, cos it looks so easy , but nothing easy for me , sure i got a big S**t cloud over me when i do a bit of diy ) Edited July 21, 2010 by Dyer864 (see edit history) Quote Link to comment Share on other sites More sharing options...
nevins Posted July 21, 2010 Share Posted July 21, 2010 Glad you got it sorted fella, was waiting for a call off you lol. Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 21, 2010 Author Share Posted July 21, 2010 Glad you got it sorted fella, was waiting for a call off you lol. Was tempted mate lol , did even ask the garage by me to av a look , but thought f**k it mate av a go ! the worst thing i cud do is TOTALLY COCK IT UP Quote Link to comment Share on other sites More sharing options...
nevins Posted July 21, 2010 Share Posted July 21, 2010 lol, it would not have been a problem for me to have come across if needed mate. Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 21, 2010 Author Share Posted July 21, 2010 Cheers bud ! bit of a drive for you tho ! all the same, thanks for the offer Quote Link to comment Share on other sites More sharing options...
evinX Posted July 21, 2010 Share Posted July 21, 2010 Good stuff, i have to do mine in a few days to Quote Link to comment Share on other sites More sharing options...
James Posted July 21, 2010 Share Posted July 21, 2010 Congrats on getting it sorted! I need to buy the other half of mine and do them! Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 21, 2010 Author Share Posted July 21, 2010 Cheers guys ! thank for the tips Quote Link to comment Share on other sites More sharing options...
p3te Posted July 24, 2010 Share Posted July 24, 2010 what a pain in the arse job this is, did mine today and 3 of them come straight out, one of the little buggers put up a fight tho but i eventually got them out, was left with this http://img841.imageshack.us/img841/5298/p1000291.th.jpg glad this jobs out the way Quote Link to comment Share on other sites More sharing options...
Dyer864 Posted July 24, 2010 Author Share Posted July 24, 2010 Glad you got it sorted mate ! little buggers aren't they lol Quote Link to comment Share on other sites More sharing options...
Rummy Posted July 24, 2010 Share Posted July 24, 2010 Should have used a bit of heat mate, seems to be the best way of getting the buggers out. Changed mine today Thought I'd try the hard way first. Soldering iron wasn't enough, got the impact driver out for a little gentle persuasion, still nothing. Tried to chisel the side of the head in an attempt to knock it round...screw just laughed... Off to halfrauds to get a blow torch, 20 bucks and 5 minutes later...voila! Heat is definately the way to do these without a doubt! Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted July 24, 2010 Share Posted July 24, 2010 I need to sort this, have you got a link to the ones with the allen key bolts Quote Link to comment Share on other sites More sharing options...
