jackso11 Posted July 18, 2010 Share Posted July 18, 2010 Trying to change the thermostat, followed the bottom rad pipe to the block but can't see where the thermostat is! Am I blind? Has anyone got a picture, need it asap thanks! Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 18, 2010 Share Posted July 18, 2010 Could be because its in the top rad pipe;) http://www.supra.co.nz/personal/cooling.gif Link to comment Share on other sites More sharing options...
baldy Posted July 18, 2010 Share Posted July 18, 2010 hi adam you will find it much easyer to remove the alternator 1st,its in the housing the bottom hose attach's too on the block,i think its 2 13 or 13 mm nuts my memory not so good these days Link to comment Share on other sites More sharing options...
jackso11 Posted July 18, 2010 Author Share Posted July 18, 2010 Hmm, I am trying to do this from the top with the airbox out...it's not going to happen is it Link to comment Share on other sites More sharing options...
jackso11 Posted July 18, 2010 Author Share Posted July 18, 2010 Thanks simon, got it done in the end. One I worked out where the nuts where it was pretty easy. Quick question for all of you in the know. The fluids section says 9L coolant for a full change. I drained everything, had the bottom rad hose offand hoses off the engine top and bottom, but only managed to get between 5L and 6L back in there. Had the engine running and rad cap off, no more bubbles. Been for a run, let it cool, rad cap off and topped up a tiny bit but I still reckon its only about 6L in there. Is there something I am not doing? Link to comment Share on other sites More sharing options...
Homer Posted July 18, 2010 Share Posted July 18, 2010 The system retains a huge abount of fluid even when the engine is (apparently) drained, I've done drains/refills on a dozen times on both my Supra's and even though they need 9L to fill from dry you'll only ever need 5-7L unless the entire engine and heater matrix are removed. Link to comment Share on other sites More sharing options...
jackso11 Posted July 19, 2010 Author Share Posted July 19, 2010 Thats good to know. At least now I can stop checking the rad cap everytime I go past to see if the level has dropped! haha Link to comment Share on other sites More sharing options...
