brake pins - the matal bit that goes acros them
Lude
part number 90240-06017 (for UK rears) £1.59 each
part number 90240-06019 (for UK fronts) £1.49 each
Better off just going down your local dealership I think dude :)
Only know because I bought them all for when I fit new pads... if you're not needing them urgently I can send you an old one of mine for just postage costs when I can.
teaches me for not reading the title properly...
Right you're looking for "Fitting Kit" and those aren't as cheap
04947-14010 for fronts £25.94
04948-14010 for rears £9.68
Not sure if they're really a reusable part though?
Give Paul a call at Whifbitz or Keron, they can sometimes beat Toyota on prices for OEM parts
Caseys those are for the pins themselves, the metal bit that goes across them is 47748-14080. This is for UK Spec brakes, i'm not sure what the p/n is if you've got J-Spec 2pots as I don't have the japanese EPC.
Ok quite confused as I believe these are UK parts I have right here.. my local Toyota dealership are pretty good at ordering and I've got a UK spec car and they go off the frame number.
http://farm5.static.flickr.com/4097/4805468574_1c23be65b6.jpg
Yeah that's the kit rather than the individual part
Ah ok :) didn't realise you could buy the parts individually outside of the kit. Learned something new today :)
Lude, as said I should be replacing all mine in about 4-5 weeks, I can see what condition the bits are that I'm replacing and send you them for just the cost of postage, but really unsure if they're that much of a reusable part. That and you may want one before that time frame.
I'm assuming you can buy it seperately I don't see why not. I've bought individual brake pins before. :)
yea they are re-usable,
does anyone know if its safe to drive without it in?
Not sure. I wouldn't make a habbit of leaving parts of your brakes out. It is called 'Spring, Anti Rattle' so that's a clue. In all honesty i'm sure it'd be fine to drive with it off but i'm no expert. You'd be as well getting one from Toyota it looks like it'll be between £5-10 according to rough prices on toyodiy.com.
